Humming Noise When Accelerating between 30-40mph
Old Aug 21, 2012 | 08:37 AM
hm923's Avatar
I've noticed a strange humming noise almost a "whir" when I'm accelerating between 30-40 mph. I've only noticed it in the morning.
Has anyone else experienced this?
Old Sep 27, 2012 | 01:14 PM
Djackson18283's Avatar
I have...noticed it today when driving @ 60-70 mph. Have you found a solution?
Old Sep 27, 2012 | 01:49 PM
aks1972's Avatar
I notice it in the morning or in case of driving after a long stoppage (hours).
It may be some kind of oil pump or something. It does sound like it is part of the design and not something breaking down.
Old Sep 27, 2012 | 08:35 PM
weather's Avatar
I am not a mechanic by any means and I may be soooooo off that people will think I am nuts but in the TL, the same description has been described as the "propeller shaft" and was somewhat common. Does the RDX have a similar device?
Old Sep 27, 2012 | 09:22 PM
AmberB's Avatar
I'm a dude you reprobates
Propeller shaft = drive shaft. Yes, the add models have a drive shaft.
Old Oct 3, 2012 | 12:36 AM
boogerdood's Avatar
I hear more of a whirring noise when lifting off the throttle and coasting, it only lasts 3-5 seconds
Old Jan 4, 2013 | 04:12 AM
Kumoi's Avatar
Spooling up sound
Just got RDX AWD w Tech and heard the same "whirring" (sounds more like something spooling up) sound. It appeared to be more pronounced soon after starting than as the car warmed up. But it would be useful to understand what it is.
Old Jan 4, 2013 | 02:49 PM
BlackDogRDX's Avatar
I just got off the phone with the service department and I can't say for sure if everyone has the same symptom but in my case the shudder / rumble was confirmed by the tech working on it and it's the VCM (Variable Cylinder Management). Basically when you're cruising at low RPM's (1000-1200 approximately) but sufficient speed to justify the transmission putting you in to 5th or 6th gear (in my case 40mph or so) the engine will hesitate or shuddle momentarily, similiar to right off the line on a rolling stop as it determines how many Cylinders to fire.
The service department called Acura factory and confirmed that this is an intended effect of VCM. They wiped my data map history with the hope that it will temporarily avoid overshifting up at such low rpms. Once I drive it a bit I will follow up.
Old Jan 8, 2013 | 01:48 PM
Dutchml's Avatar
I hear the same "whirring" sound at idle, cold or hot. But I can also duplicate the noise by turning the ignition to "on", but it only lasts about 3 or 4 seconds. With the engine running, it's constant. Any guesses?
Old Jan 8, 2013 | 02:15 PM
GRDX's Avatar
My guess is that what you are hearing is the electric fuel pump. It would be on all the time while the engine is running. When you turn on the ignition but do not start the car it would pump until it makes the proper pressure and then stop since the engine is not using the fuel.
Old Feb 24, 2014 | 12:53 PM
daze05rl's Avatar
I know this is old but was just wondering if anyone ever found a good solution to this. I own a 2005 Acura RL and while im driving under 30mph its normal as soon as I hit 30 I get a humming noise wich sounds to me like its coming from the passenger side of the dash board. once I hit 40mph it goes away.
Old Feb 25, 2014 | 02:06 PM
dgerry2's Avatar
I hear the same noise with my '13 RDX, especially when coasting at 30-40 MPH. Just had mine in for service and the '14 RDX loaner made to same noise. Doesn't sound like an issue to me, just something with the design.
Old Nov 18, 2014 | 07:26 PM
ribs's Avatar
6th Gear
I have a 2015 RDX and I heard this whirring sound after driving it the first 100 miles. In my car, it was very noticable under a steady cruising speed of 35-37 MPH.
I brought it to my dealer, they diagnosed it as the rear propeller shaft bearing. The bearing is an intergral part of the shaft, so they replaced the entire shaft/bearing assembly.
I then drove the car home, drove it to work and....the whirring sound came right back. The car is currently back at the dealer today. They are telling me they will get to the bottom of the issue and they are working with Acura engineering (o.k. great).
I have read that there is a quality issue with these prop shaft/bearing assemblies at the manufacturer/source. I won't be surprised if they once again replace the replacement assembly they installed as it probably also has a bearing flaw. I told them to keep the car until they solve the problem.
If they get to the bottom of the issue successfully, I'll report back with the solution!
BTW, the 2015 RDX loaner I am presently driving doesn't make the same sound.
Old Dec 4, 2014 | 07:10 PM
ribs's Avatar
6th Gear
The dealer has given me a loaner and is all-over the issue, thankfully, and they now have the o.k. from Acura to replace the transmission. Let's hope that nips it in the bud because they had already replaced the propshaft, rotated the tires, and eliminated the chance that it could be coming from the propshaft transfer case.
I don't know about other owners, but to be blunt, I can't pay high 30's for any new car that I drive around town in this speed range all the time and have to drowned-out the sound with the radio whilst it constantly makes a driveline sound like a washing machine spinning a load at 500 rpm.
Old Apr 25, 2015 | 11:51 AM
da-suu's Avatar
7th Gear
i know this is like a year old, but has anyone found out the issue ?
Old Jun 29, 2021 | 04:27 PM
RL 08's Avatar
I know that I'm 9 years behind but have you find out what the issue was?
Mine is the same exact thing that you are describing. I have a 2008 RL Base
Old Jun 29, 2021 | 04:28 PM
RL 08's Avatar
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Mike734
Dec 10, 2021 01:25 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
copmagnet82
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
