Handling questions
Old May 27, 2014 | 10:21 AM
mharelick's Avatar
6th Gear
Handling questions
Hello:
I have a 2013 RDX with the Technology package
I have notice the following handling issues. I would like to know if they are normal or if they are defects that I should have looked at.
1) AWD handling. On gravel, unpaved roads or pavement that has the first hints of rain I have observed that there is slippage, and I have to reposition the vehicle to keep it straight. I thought this would be resolved by AWD.
2) Bumpiness. On unpaved roads there are occassionally these depressions. In cars with AWD I have driven over them slowly if they could not be avoided. When I do this I normally feel a small bounce. In the RDX when I do this it feels like the whole car is bouncing up and down.
3) Sharpness of turns. In other cars when I slow down to go into a curve, we barely feel it. In the RDX passengers comment that turns feel "harder" in the vehicle than other cars.
How much of this is "just the way it is", and how much of it can be repaired?
Old May 28, 2014 | 09:11 PM
kareshi's Avatar
If I am right, you're new to SUV like me.
The SUV has a higher center of gravity and therefore #2 and #3 will be more pronounced compared to a passenger car.
For #1, I am not sure.
Old May 29, 2014 | 08:01 AM
ceb's Avatar
ceb
Normal
Old May 29, 2014 | 08:13 AM
even tho they toned down the suspension for the 2nd gen RDX, it still is a sporty ride.
and P.S. AWD will not make up for shitty tires...
so, if you're getting slippage at the first sign of rain, your tires are at fault.
Old May 29, 2014 | 09:00 AM
hondu's Avatar
Originally Posted by mharelick
Hello:
What cars are you comparing the RDX against as your point of reference? Suspension calibration and handling between vehicles can be dramatically different (even in the same vehicle class).
Old Jun 1, 2014 | 03:12 AM
YeuEmMaiMai's Avatar
1. the RDX is a slip and grip type of AWD (ie it is FWD first and when those wheel slip then it goes into AWD) it is common for FWD to slide sideways when the front wheels spin (just like any other FWD car would)
2. RDX has a much softer ride than most cars do (read it's for the old people) and combine that with a higher center of gravity and the motions are more pronouced
3. what do you mean by harder? Do you mean people feel it more? IF so, that's to be expected as you are higher off the ground.
Old Jun 10, 2014 | 10:14 AM
mharelick's Avatar
6th Gear
Comparing
I am comparing the RDX to a subaru forester and a Volvo XC60.
Old Jun 10, 2014 | 10:15 AM
mharelick's Avatar
6th Gear
I am new to part-time AWD.
Aug 15, 2019 12:58 PM
tman570
Jun 11, 2019 07:56 AM
divac
Aug 29, 2018 10:13 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
