Dim lights in lower center console?
Old Feb 20, 2022 | 11:03 AM
bigbee's Avatar
9th Gear
I notice that the lights behind the gearshift indicator and the heated/vented seat buttons are very dim and can barely be seen at night. Are all RDXs like this or is something wrong there. I removed the panel above the cubby with the little light in it and measured the voltage there at only 4.2 volts. The fuse that supplies this lighting circuit has 12 volts so wondering if I have an issue there or if it's as designed and if so does the body control computer drop the voltage down or what? Thanks for any input.
Old Feb 21, 2022 | 04:03 AM
Kelsen's Avatar
I do not know the answer to this question, but for those that can provide info, it is always useful to mention the year and trim of your vehicle.
RFT!!!
Dave Kelsen
If you keep your feet firmly on the ground, you’ll have trouble putting on your pants.
Old Feb 21, 2022 | 06:28 AM
bigbee's Avatar
9th Gear
Sorry. It's a 2018 RDX Advance
bsunder11
Nov 13, 2013 06:36 PM
djtsmith007
Jul 19, 2010 02:14 PM
Road Luxury 05
Sep 15, 2009 07:57 AM
Lexusconvert?
Feb 5, 2009 08:48 PM
Novice
Jan 19, 2004 11:11 AM
