Center console lights
Old Oct 19, 2013 | 09:14 PM
bsunder11's Avatar
Hey everyone,
My center console lights for my radio, navi and gear box is not working. Where can I locate the fuse to see if it needs to be changed?
Old Oct 20, 2013 | 11:37 AM
beastUA6's Avatar
Probably under the dash on the drivers side near the lever to pop the hood.
Old Oct 20, 2013 | 09:50 PM
Superunknown's Avatar
It's more likely those little bulbs have gone out.
Old Oct 21, 2013 | 02:40 PM
M_Jet's Avatar
5th Gear
I am having this same problem, except with just one damn button
Old Oct 21, 2013 | 04:15 PM
vietxquangstah's Avatar
if the fuses are fine you probably have several burnt out bulbs
Old Oct 21, 2013 | 08:11 PM
TegoTL's Avatar
LED conversion...
Old Nov 13, 2013 | 01:24 AM
bsunder11's Avatar
How would I be able to change those bulbs?
Old Nov 13, 2013 | 01:28 AM
paperboy42190's Avatar
with skill
Old Nov 13, 2013 | 03:50 AM
Gil'sUA5's Avatar
Originally Posted by TegoTL
LED conversion...
this. those bulbs burn out on all 3g TL's so don't even bother checking fuses unless every single one of them is out. The LED conversion isn't cheap but its something you do once and you'll never have to do it again. Im personally looking for somebody that sells these LED's.
Old Nov 13, 2013 | 01:36 PM
Gnargasim's Avatar
I started a topic about this a little bit ago (well close to it)
Hope it helps in someway
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/center-console-lights-898072/
Old Nov 13, 2013 | 06:36 PM
mrsimeon's Avatar
Just get the replacement bulbs. And slip them in the turn housings, that hold the lamps.
Buy the bulbs and replace them all when in the dash.
And steering wheel,
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
PortlandRL
Sep 14, 2015 12:01 PM
