Brake light wiring diagram?
Old Jul 8, 2025 | 09:21 AM
jcountry's Avatar
I have a 2013 Acura RDX and only one brake light is not getting power, my passenger side brake light. The only fuse I found is is good, bulb is good, and the bulb socket is good.
i stripped the wire itself back and confirmed no voltage on the wire itself.
I need to find where the wire junctions so I can test continuity on the wire and trace the problem back from there. Any help would be greatly appreciated.
Old Jul 8, 2025 | 09:24 AM
I would just start following the wire loom up the lift gate and you'll probably find your culprit. wiring harnesses and moving liftgates/trunk lids typically lead to some broken wires in there. You won't have to go very far.
Old Jul 8, 2025 | 09:29 AM
jcountry's Avatar
Does the wiring go up and over? I thought it went down and over under the spare tire hatch. It’s hard to see because the speaker has to come out to see where the wiring runs.
Old Jul 8, 2025 | 04:38 PM
Sorry, i read tail lights, didn't realize the 2013 RDX's brake lights are actually on the body. you'll need to follow the wiring either way.. a wiring diagram won't help in that case :/
Old Jul 8, 2025 | 08:45 PM
altair47's Avatar
EATSLEEPRACE
Jul 7, 2011 06:04 AM
agent g 5
Nov 23, 2006 02:45 PM
MeldyS26
23
Feb 4, 2005 02:34 AM
KaMLuNg
Aug 30, 2002 11:22 PM
JasonT
Dec 18, 2001 12:31 AM
