2017 RDX Tailgate Problems
Old Nov 11, 2017 | 12:04 AM
Bluebell's Avatar
3rd Gear
I have a 2017 RDX and the power tailgate does not work when it is cool/cold, 0c/32F.
Old Nov 11, 2017 | 07:27 AM
Ron A's Avatar
Administrator
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Old Nov 12, 2017 | 06:11 AM
Gadgetjq's Avatar
Inveterate Tinkerer
If you're under warranty, take it to your dealer. If not you should provide more information. Doesn't work only with the interior button, only with the tailgate button, not at all? Have you tried changing the fuse? A tiny crack in the element that wouldn't cause a problem when warm might separate when the metal gets cold and break continuity.
Cheers!
Old Nov 15, 2017 | 11:35 AM
Bluebell's Avatar
3rd Gear
Hi there. The power tailgate operated correctly as long as the vehicle was warm, (if it sat in the sun, or was parked in a warm garage overnight). As soon as it sat outside in cooler weather, around 0 - +5 celsius it would open via the button in the dash or the tailgate, but would not close via power. I had to manually close it. It stayed like that, (manual operation only) until the veh got warm again. The Acura dealer in Edmonton couldn't replicate the problem, and they had it parked in their lot over night. The dealer in Kelowna, BC repaired the "Tailgate closer unit half latch switch". I was also getting error messages from AcuraLink: Low Oil pressure, Electric power steering, and charging system wasn't operating correctly. Turns out those issues were nothing. As the weather is getting cooler here, I guess time will tell if the issue was fixed!
Old Nov 21, 2019 | 09:20 PM
Ray Su's Avatar
5th Gear
Have you find out what's the reason?
Old Nov 22, 2019 | 09:20 AM
fcostantini's Avatar
I have had two instances where my 2017 Advance's power tailgate stopped working for a while (regardless of which button I used to control it), but after some driving it fixed itself within half a day. I have not yet taken it into the dealer to have it looked at. Mine occurred in 50F weather and in 70F weather. I am curious as to how Bluebell's situation got resolved.
Old Nov 22, 2019 | 03:04 PM
Bluebell's Avatar
3rd Gear
Tailgate
The dealer could not find an obvious fault even though I brought the RDX in with the tailgate malfunctioning. This was the 2nd time at this dealer, and they resolved the issue by replacing the entire locking mechanism in the tailgate. No charge, and it hasn’t failed since then. Coming up on a year. Hope this helps
EE4Life
3G MDX (2014-2020)
May 2, 2025 07:44 AM
EE4Life
Sep 1, 2023 11:05 AM
CadiGTi
Dec 11, 2016 07:58 AM
EE4Life
2G NSX (2017+)
Jul 14, 2016 09:09 PM
EE4Life
Apr 3, 2015 07:56 AM
