2017 RDX - Intermittent Engine Noise
Old Sep 22, 2024 | 08:48 AM
Bwright6404's Avatar
Hello, new to the group. We have a 2017 RDX with 61k miles, we bought it used with about 47k. A few months ago, I noticed a fairly significant ticking noise. However, it is not a constant tick, it comes and goes without any obvious reason. I have attached a video I took when it was making the noise, see attached (note the fan starts in the video). The tick goes away with an increase in RPM and seems to happen more frequently as the oil life declines (currently at 40%). I do not get an oil pressure light or check engine codes. Also only seems to happen when the engine is hot, not on a cold start.
I brought it to the local Acura dealer to show them the video. When I arrived, it was not making the noise but when I went to leave it started so the tech came out to listen. They basically said they have no idea what it could be, primarily because it comes and goes.
Any suggestions would be great.
File Type: mov
Old Sep 22, 2024 | 11:39 AM
Alex Medeiros's Avatar
alexmed2002
It sounds like lifter tick, but it's hard to diagnose without looking into the motor. It's possible it could be other things like a bad pulley or something, but you need to have it looked into further.
Old Sep 23, 2024 | 05:19 PM
Skidoor's Avatar
run some Sea Foam in the crankcase for a few weeks then change the oil
Old Sep 26, 2024 | 06:04 PM
altair47's Avatar
Is there a distinct engine knock, is the oil level OK? If so, you need to remove the beauty cover and determine which head the knock is coming from, then remove the valve cover, do a visual inspection and check the condition of the springs on the rockers.
Old Oct 1, 2024 | 07:24 PM
DCS's Avatar
DCS
It would be very helpful to better locate the area where the sound is coming from, rear or front valve cover area or timing belt cover area.
Nates NJTL
Feb 10, 2023 10:49 AM
arek1200
2G RDX Problems & Fixes
Jan 14, 2023 02:12 PM
98GTSViper
Dec 13, 2021 06:13 PM
easydrive
Apr 20, 2018 11:44 AM
Lalin
Dec 22, 2016 02:34 AM
