2014 RDX Heat issue (Not the normal problem)
Old Jan 15, 2026 | 07:58 AM
StaceysRDX's Avatar
Angry 2014 RDX Heat issue (Not the normal problem)
Hello fellow RDX friends
So my 2014 has no heat on the drivers side, It is NOT the blend door. Here is a list of what I have done so far:
Replaced the blend door motor, it is working as it should
Flushed the heater core frontwards and backwards
I found that the AC compressor was cycling on and off so I removed the fuse to the compressor clutch.
Still no heat on the Drivers side. I can feel the warmth in the box, but only getting cold air out of the vent?
What do I check next???
Old Jan 15, 2026 | 12:36 PM
Alex Medeiros's Avatar
alexmed2002
Is your coolant hitting the correct operating temps and is your thermostat old? The only other thing that I can think to check is if any hoses or air dam pieces are missing (the parts that lead the air out to where you choose).
Old Jan 16, 2026 | 08:17 AM
StaceysRDX's Avatar
It is getting to full temp. You may be correct, the air dam may not actually be moving even though the shaft is turning.
That can not be a fun part to get to.
Old Jan 16, 2026 | 10:18 AM
jimbo1763's Avatar
I had a similar problem on my old Mercedes a while back. Does the defroster work? I used to be able to get heat to the cabin vents by first enabling the defroster, waiting until hot air got to the windshield, then going back to regular heat settings.
beerman831
Jul 26, 2024 04:09 PM
ovation
3G RDX (2019+)
Jun 10, 2024 07:17 AM
Pete.Mahone
Aug 14, 2023 09:04 AM
ronsteve2112
2G RDX Problems & Fixes
Jul 28, 2021 04:57 PM
Murillo81
May 31, 2018 03:07 AM
