2013 RDX shaking when accelerating
Old Apr 3, 2021 | 09:37 PM
ENSONIQ's Avatar
5th Gear
2013 RDX Shaking when accelerating, usually around 1.5K to 3K RPMs and usually when going up the hill.
No Check Engine light and no DTC codes at all.
To me seems like it’s either engine, transmission or awd system, but what do I know.
also often when accelerating either uphill or on level surface, around these same RPMs, there is a high pitch noise, but this noise happens when the shaking doesn’t happen. It’s either the shaking or the noise, unless the shaking is louder than the noise and I don’t hear it when the shaking happens. The noise sounds to me like an electronic coil or small transformer noise.
but I’m mostly concerned about the shaking.
Old Apr 7, 2021 | 10:22 AM
hongthan's Avatar
I will check tires, suspension and wheel bearing first whenever I have a shaky steering wheel.
Old Apr 7, 2021 | 12:45 PM
ENSONIQ's Avatar
5th Gear
steering wheel doesn’t shake tho.
but the rest of the car does
Old Apr 7, 2021 | 03:15 PM
hongthan's Avatar
Wheel bearing can cause vibration without causing steering wheel shake. You can also check the engine mount.
Old Apr 7, 2021 | 07:25 PM
dtownfb's Avatar
How many miles do you have on your 2013? When was the last time you changed the transmission fluid and transfer case fluid?
Old Apr 7, 2021 | 07:36 PM
ENSONIQ's Avatar
5th Gear
52,000 miles.
I never changed neither of those fluids.
Im second owner, but I’m sure first owner didn’t charge them either. I bought it from first owner it had less than 10k miles on it.
Old Apr 7, 2021 | 08:39 PM
dtownfb's Avatar
I would start by changing the transmission fluid and transfer case fluid. There are "how to" videos on this forum that show how to do each. If you are handy, it pretty easy.
Old Apr 8, 2021 | 06:53 AM
Kelsen's Avatar
I had a similar problem with my 2004 Accord Coupe; it seemed to happen in a particular range (from about 58mph to 63 mph), and while not very bad, it was worrisome. I made it go away (about 90% gone, at least) by changing both lower control arms in the suspension.
RFT!!!
Dave Kelsen
I can't think of anything worse after a night of drinking than waking up next to someone and not being able to remember their name, or how you met, or why they're dead. -- Laura Kightlinger
Old Apr 12, 2021 | 11:54 PM
egads's Avatar
All Honda/Acura automatics require regular transmission fluid changes. That would be code 3 on the maintenance minder that comes on when the oil life reaches 15%.
That said, there is an additional item you can read about here:
http://www.urvi.net/forumfiles/SB/B17-017.PDF
Appraiser77
1G RDX (2007-2012)
66
Jan 14, 2022 12:25 PM
dopeboy1
Apr 10, 2021 07:27 AM
WPJoe
3G RDX (2019+)
75
Apr 24, 2019 11:08 AM
Lalin
Dec 22, 2016 02:34 AM
g0bl0k
1G RDX (2007-2012)
17
Feb 28, 2007 03:56 PM
