Oil filter substitute
Old Jul 18, 2015 | 05:55 PM
spartan77777's Avatar
Question Oil filter substitute
Using WIX 57536 oil filters for my 2013 RDX AWD. Have a few leftover WIX 51334 from my Acura TL. Would like to use them on my RDX. They appear to be same in every way exception of the burst pressure. WIX 57536 has 363 psi burst pressure while 51334 280 psi. Anyone know if it is OK to use the 51334 on RDX with 280 pis burst pressure?
Attached Thumbnails Oil filter substitute-57536.jpg   Oil filter substitute-51334.jpg
Old Jul 18, 2015 | 08:25 PM
andysinnh's Avatar
Considering Honda uses the same OEM filters across all their line, including the RDX and TL, I would guess you'll be ok.
Andy
Old Jul 20, 2015 | 07:57 AM
ceb's Avatar
ceb
Andy
Right. What's the worst that could happen? You could lose oil pressure driving on the freeway but that isn't too bad - or is it?
What's the burst pressure on an OE Honda filter?
Old Jul 20, 2015 | 08:02 AM
i'll 2nd the honda filters are interchangable between all models.
ive been using the s2k filter on my 3rd gen TL.
Old Jul 20, 2015 | 12:11 PM
andysinnh's Avatar
So you actually think that an RDX has higher pressure than a TL? If WIX is making a filter that is so close to the edge that it supports a TL but not an RDX, then that's definitely not wix-like. The OEM honda filters are made by Fram these days, and I'd guess that it has lower burst pressure than anything WIX will make. I can't believe there's a risk......
Old Jul 20, 2015 | 12:47 PM
ceb's Avatar
ceb
No, but there has to be some reason for somebody to make two different filters. The engineers didn't wake up some morning and say "let's make things more expensive for ourselves and our resellers by creating a whole new (but identical) filter". A filter is under $7 when you buy 5 - do you want to take that chance without researching why they have different filters?
Old Oct 13, 2015 | 08:12 PM
Mr_MDX's Avatar
280 is safely above OEM spec for oil filter burst pressure.
rcs86
Aug 2, 2016 06:52 PM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
jmaxima03
Sep 27, 2015 10:22 AM
