LED 'reverse' light bulbs
The Original Shawdy
Looks good. I'm planning to upgrade some more LED's on both the RDX and TL. Should be some good sales coming up.
2021 RDX A SPEC
LED backup bulbs. (Allow up to 30 days to receive them)
12W HID White 921 T15 Backup Reverse LED Lights Projector Lens Bulbs White | eBay
license plate bulbs. (Purchased locally from a Vancouver supplier but I'm sure you can source them on eBay)
1st one listed - Samsung LED '7.99 ea
Wedge Bulbs | Autolismo
The following 2 users liked this post by Acura604:
carbonTSEX (11-24-2015),
yesrdx (11-24-2015)
The Original Shawdy
I'm currently running VLEDs for all my bulbs. They're local for me though so shipping is 2-3 days.
yesrdx (11-24-2015)
Thanks for the info, guys. I'm not much of a fan of ordering from Ebay and not knowing when the parts will arrive. Carbon, can you tell me the part# (link) for the parts required for the reverse tail lights and license plate lights for VLED?
The Original Shawdy
5K WHITE 4 LED HIGH POWER BULBS 194 168 158 160LM | 1 PAIR - 194 - 168 - 158 LED - Shop Bulb #
For reverse lights I will be ordering:
5K WHITE 15 LED HIGH POWER BULBS 917 918 920 921 922 923 579 500LM | 1 PAIR - 921 LED - Shop Bulb #
The bulbs are high quality and extremely bright. I am also running the 194 5k white bulbs for the door puddle light and they light the ground up big time. I highly recommend them. If you have any issues, VLEDS.com will replace them no questions asked. I prefer the 5k pure white for my wife's 2016 RDX because it looks original and matches the rest of the exterior lighting. Another good site is ijdmtoys.com for lighting. Hope that helps. I should have pictures of the lighting in my build thread in the photo section.
Good Luck!
yesrdx (11-25-2015)
LED bulbs installed in my RDX. All from VLEDS, all very good choices:
Reverse/ Backup:
5K WHITE 15 LED HIGH POWER BULBS 917 918 920 921 922 923 579 500LM | 1PAIR
Part #: 921_15_W_5K
License Plate:
194 5K WHITE 6 LED HIGH POWER 360° 180LM | 1 PAIR
Part #: 194_6_W_5K_N
Dome:
5K WHITE 6 LED HIGH OUTPUT DOME LIGHT BULB 170LM 31MM 3175 DE3175
Part #: 3175_6_W_5K
Door/Puddle:
5K WHITE HIGH POWER LED BULBS 194 168 158 80LM | 1 PAIR
Part #: 194_HP_W_5K_N
Cargo:
5K WHITE 4 LED HIGH POWER FLANK BULBS 194 168 158 160LM | 1 PAIR
Part #: 194_4_HPF_W_5K
Reverse/ Backup:
Part #: 921_15_W_5K
License Plate:
Dome:
Part #: 3175_6_W_5K
Door/Puddle:
Cargo:
One of my backup light has burn out and I try to replace it with the LED I have now. But I'm still struggling with taking the old bulb out. Why is it so hard to turn and pull the bulb out? I'm afraid I might have damaged something.
The Original Shawdy
On a side note the rest of by LEDs came in from VLEDS.com cyber monday sale. Came in 1 day. Finishing the RDX lighting today. Ordered a pair for rear cargo, dome light and reverse lights. All in 5K. The rest are for my TL and in 6k. Will update my build thread with photos once installed in the photo section.
The Original Shawdy
Just finished swapping out center dome light, rear cargo lights and reverse lights. All together it took me maybe 10 minutes. The reverse lights came out no problem with needle nose pliers and light pressure. You just need to twist them counter clock wise and pull down. Didn't take much effort at all.
brenakie (03-06-2019)
The Original Shawdy
Yes I agree. However, all the lights have been converted to 5k now and we leave the door/dome light switch off anyway. It's just there if we need it.
The Original Shawdy
Yes I swapped mine on the rear hatch to VLEDs 5000k flank bulb. Lights up the whole trunk and ground like crazy. Definitely worth the upgrade. I don't have a night picture unfortunately but I can get one later. I do have a comparison photo between the LED and halogen during the day.
![Name: FCBF210D-48F4-4AFC-9800-E29CD104CEB2.jpg
Size: 175.5 KB](https://acurazine.com/forums/attachments/2g-rdx-diy-faq-406/46374d1501278376-led-reverse-light-bulbs-fcbf210d-48f4-4afc-9800-e29cd104ceb2.jpg)
![Name: 332D03CA-B79C-4F68-90F4-C3C71011D76D.jpg
Size: 91.3 KB](https://acurazine.com/forums/attachments/2g-rdx-diy-faq-406/46375d1501278376-led-reverse-light-bulbs-332d03ca-b79c-4f68-90f4-c3c71011d76d.jpg)
![Name: AF922C8C-6578-4508-A94A-8C97486FDD15.jpg
Size: 91.9 KB](https://acurazine.com/forums/attachments/2g-rdx-diy-faq-406/46376d1501278376-led-reverse-light-bulbs-af922c8c-6578-4508-a94a-8c97486fdd15.jpg)
![Name: 50C0BC05-2E2B-4B67-B779-3478BD8B38BF.jpg
Size: 104.2 KB](https://acurazine.com/forums/attachments/2g-rdx-diy-faq-406/46377d1501278376-led-reverse-light-bulbs-50c0bc05-2e2b-4b67-b779-3478bd8b38bf.jpg)
![Name: DE4A6016-01DF-4A5F-86EC-F21E3DA7CF3A.jpg
Size: 86.1 KB](https://acurazine.com/forums/attachments/2g-rdx-diy-faq-406/46378d1501278376-led-reverse-light-bulbs-de4a6016-01df-4a5f-86ec-f21e3da7cf3a.jpg)
As you can see with the LED you can't even tell were the bulb cover is because of the brightness, unlike the halogen. The bulb type is in the picture if you are interested in the same one.
mr. samster (12-08-2015)
The Original Shawdy
The Original Shawdy
mr. samster (12-11-2015)
2021 RDX A SPEC
^^^ that looks freaking amazing.
IN the interim until I find a good set of LEDs for my hatch...I've removed the 921 reverse halogens (replaced by LEDs) and inserted them in the hatch...although regular halogen, wow they are significantly brighter than the weak sauce 168s.
![](http://image.dhgate.com/0x0s/f2-albu-g1-M01-81-21-rBVaGVUaSgiAbCXpAAYnyNXwLX4187.jpg/12v-w16w-t15-toshiba-high-brake-lamp-t15.jpg)
The Original Shawdy
It's super easy.
Take off the cover panels on each side of the tailgate with a flat head screwdriver. The same panels that have the tailgate interior lights. Disconnect the plug from the reverse light bulb. Using your hand or (like many others) use some needle nose pliers and twist counter clockwise. They bulb should twist out. Install new bulb into the socket and do steps in reverse.
Note: I plugged the bulb into the socket and reconnected it to the harness and let it hang. Hoped in the car and put it in reverse. Second push on the push start without foot on the brake and you can move the shifter. Make sure the bulb is working. If not, unplug it and twist it 180 degrees and try again. Then reinstall.
I had a pair of the bulbs pictured by the OP laying around and thought "great now I can use them". Much to my dismay I couldn't get them into the housing. Too large. I guess what I have is slightly different.
Do this!! I did this 2 weeks ago on my wife's 2015 awd tech... easy, quick, inexpensive, and results are very noticeable. Went with VLEDs @ 5000k. No hyperflashing/problems.
carbonTSEX (12-05-2016)
I tried a 13 chip T10 LED (local source) which didn't prove to be any better. Also had another member recommend the Philips below.
921 Philips LED Bulb | T16 Philips LED bulb | LED Wedge bulb
Jammer (05-31-2020)
Texas325
01-14-2017 07:59 AM
blownby
11-19-2015 10:10 AM
