Jack / jack stands / jacking points
Old May 2, 2024 | 01:21 PM
samiam_68's Avatar
I would like to purchase a new floor jack and a set of jack stands for occasional use - tire rotations, brake jobs, oil changes, etc. Does anyone have any recommendations for brands / places to buy? I don't want cheap Harbor Freight junk unless they have some good quality items as well.
Besides the standard jack points in the attached PDF, are there any other spots I can use for the floor jack on the RDX? I specifically want to be able to lift just one side of the car (left or right) and place it on jack stands.
Also looking for a decent 1/2" impact wrench - any recommendation on that?
Old May 2, 2024 | 03:21 PM
Harbor Freight jacks (especially the new Daytona branded ones are far from junk. https://www.harborfreight.com/automo...een-64784.html
get either the Dewalt or Milwaukee 1/2" impact.
Old May 2, 2024 | 03:52 PM
mrgold35's Avatar
mrgold35
I do my own tire rotations on my RLX sport hybrid and MDX Sport Hybrid. I purchase a 4-ton Powerbuilt 520516 U-Jack, Amazon, $190:
Amazon Amazon
This floor jack has a U shaped contact pad for the Acura jack points to slide a jack stand into place. I already had jack stands and wheel chock I purchases years ago on Amazon. I have a bunch of Ryobi tools (sander, blower, fan, angle grinder, lights, jig saw, buffers, etc...) and batteries. I just needed to purchase the P262 1/2 impact wrench tool only for around $100. I also have a tq wrench, Ryobi P747 tire inflator, and non-marring lug nut socket (impact to take off lugs, tq wrench to put on lugs).
Old May 2, 2024 | 06:43 PM
John from PA's Avatar
Check the
UniJack UniJack
. It is a combination jack/jack stand. I used them for many years doing work on my Posche.
Old May 3, 2024 | 05:39 AM
altair47's Avatar
You're right, Daytona is the best!
Old Jan 29, 2025 | 03:13 AM
Gigadrill's Avatar
4th Gear
For a floor jack, I went with a Torin Big Red—solid quality and not crazy expensive. For jack stands, I’d suggest looking at ESCO; they’re super sturdy and have flat rubber tops that are gentle on your car’s jack points. As for jacking one side of the car, I’d stick to the reinforced pinch welds or frame rails. Just double-check your manual to be safe!
Old Feb 26, 2025 | 03:07 AM
Gigadrill's Avatar
4th Gear
and for the impact wrench, I’ve been using a Milwaukee M18 1/2" cordless, and it’s been a beast for everything from lug nuts to stubborn bolts.
If you’re thinking of future upgrades, I’d recommend a scissor lift nz from Astrolift. I eventually added one, and it’s made jobs like brake work so much easier.
helloha1
Jan 15, 2014 01:27 AM
myztix
Apr 28, 2012 02:02 PM
bigeshorte45
May 5, 2008 08:33 PM
o1s
Apr 28, 2008 05:02 PM
Slimey
Jun 1, 2002 06:55 PM
