2013 RDX Low Beam - stumped
Old Nov 24, 2020 | 12:07 PM
srgilbert's Avatar
Perhaps someone else has a possible solution. The right low beam lamp went out. I purchased a couple new Halogen bulbs (original 9004) and that did not solve the problem. I went to the left lamp and tried one of the new bulbs and it worked fine. I took the old working bulb and tried it in the right side - still not working. I tried all the fuses under the hood and all seemed fine with a multimeter. The plug is not melted and looks OK. Any ideas - what am I missing?
Thanks!
Old Nov 24, 2020 | 12:37 PM
Alex Medeiros's Avatar
alexmed2002
Are you getting any power to the plug?
Old Nov 24, 2020 | 12:39 PM
srgilbert's Avatar
I hadn't thought of that - will give it a try I would expect no power otherwise the bulbs would have worked.
Old Nov 24, 2020 | 12:45 PM
srgilbert's Avatar
No power to the plug....fuses under hood ok - driver side head lamp work fine?
Old Nov 24, 2020 | 12:49 PM
alexmed2002
Is the wire that goes to the plug still ok? Like is it tangled or cut up anywhere? Try following the wire and check that it's still intact.
Old Nov 24, 2020 | 01:01 PM
srgilbert's Avatar
All looks normal - the head lanp is on a 12" stub that feeds back to a larger bundle.
Old Nov 24, 2020 | 01:06 PM
Check the relays, find a similar one and swap it to rule that out
Jeckz
Dec 18, 2020 09:44 AM
JTarwa
Oct 7, 2020 03:39 PM
Lemi
Oct 3, 2020 11:20 AM
Poolman
Jan 19, 2020 06:38 AM
user 708208232
Feb 28, 2016 10:53 AM
