Where to find HFL version
Old Mar 13, 2014 | 11:39 AM
dgerry2's Avatar
How do I find out what HFL software version I have in my '13 RDX? I just had a new cable reel installed in my steering wheel, as part of the repair they told me they needed to "re-flash" the computer. This was just a couple of weeks ago, so I am trying to see if I still need to get the latest HFL update (for Siri Eyes Free), or if it might have been done during my repair.
Old Mar 13, 2014 | 11:50 AM
GRDX's Avatar
I posted the Siri Eyes Free software update instructions in one of those titled threads. It is a PDF download it and read it you should be able to figure it out as it will show the version in the beginning steps (different depending on tech or non-tech) then once you know the version stop the procedure nothing will change.
Old Mar 13, 2014 | 11:54 AM
dgerry2's Avatar
Thanks, was hoping there was an easy and quick way. Don't really want to get into connecting a battery charger, etc.
Old Mar 13, 2014 | 12:40 PM
GRDX's Avatar
It is not hard and only takes a minute or two once you have it down. No charger needed you are not doing the re flash just the first few steps to get to the screen that displays the software version then abort. Even if you did the entire procedure the charger is not needed if you have it running. They just don't want you to chance killing the battery while the module is being re flashed because then it will become a paperweight. You are only checking the version.
Old Mar 13, 2014 | 12:43 PM
ottoman101's Avatar
When I ran my Siri upgrade I just let the car run. No battery charger, and it worked.
At the "OK" startup screen just hit Map+Dest+Cancel together for 3 seconds, select diagnosis mode, scroll to and select HFL, and it will display the version.
Disclaimer: Dont mess with any settings without knowing.
Old Apr 5, 2014 | 07:46 AM
diawa944's Avatar
3rd Gear
What is the latest HFL software revision?
Old Apr 7, 2014 | 11:59 AM
ottoman101's Avatar
I had updated to 2.1.0.0 back in February. That might still be the latest.
Old May 27, 2014 | 12:37 PM
yuxmyyg's Avatar
5th Gear
I have just upgraded my HFL by myself with 12 packages and Siri Eyes Free. I checked again the version just 2.0.000, not 2.1.000.
Why was that ? I have RDX Tech package AWD, BTW.
agupta3224
May 23, 2017 08:30 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
eastcoastguy
Sep 23, 2015 06:29 AM
