Valve Stem Caps
Valve Stem Caps
Forgot to tell the dealer to leave my tires alone at my latest service. So --- now I'm short both valve stem caps on one side. And, of course, the dealer just shrugs his shoulders. Is there anything special about OEM caps or just go to Autozone?
just go to the nearby parking lot and grab the first two you see
The following 2 users liked this post by thoiboi:
Ludepower (09-20-2020),
musty hustla (11-19-2016)
mrgold35
You can always steal the ones off the spare tire on your car(s) until you hit the auto parts store. I have Acura logo valve covers and have to double-check the tech puts them back after a tire service.
I'd go outside and look at some of his new cars on the lot. Bend down to tie your shoe and voi-la..............there are a couple of caps just waiting for you. If they ask where you got them..........just shrug your shoulders.
The following 2 users liked this post by rosen39:
dirleton (11-16-2016),
justnspace (11-18-2016)
I've been using metallic valve stem caps without any problems so far. Just look at eBay and you can get one set for $5-6. It comes with a stylish Acura logo and an Acura key chain.
http://m.ebay.com/itm/ACURA-VALVE-STEM-CAPS-KEYCHAIN-WHEEL-TIRE-CHROME-US-SELLER-VS02-/262673214783?hash=item3d288b2d3f%3Ag%3A8l0AAOSwoudW-C4I&_trkparms=pageci%253A0989a968-ad34-11e6-9ca5-74dbd1800a2d%257Cparentrq%253A7532201f1580a6062573eb56fff6d249%257Ciid%253A5Something like this. The key chain can be used as a spanner to loosen the nut if by chance it is stuck. I haven't had to use the key chain yet.
Mine was missing a gray cap after the last service and I went back to parts and asked for one. They handed me a new one gratis. I noticed it has a slightly different shape than OEM, but at least it matches as far as color. Next time I get a loaner I am taking a couple of caps.
ACURA VALVE STEM CAPS + KEYCHAIN WHEEL TIRE CHROME - US SELLER VS02 | eBay
why go through ALL of that hassle with spanner key chain wrenches, when you can just use a plastic black cap or no cap at all...
you do know that its a chemical reaction? and it will bind/seize! because SCIENCE!!!!!!
It's called galvanic corrosion, look it up y'all! Especially those in snow states or humid climate
justnspace (11-18-2016),
WheelMcCoy (11-20-2016)
You mean the valve stems will corrode and break???
You guys are making me change my mind. Okay I'll start looking for plastic caps now. Thanks.
What can happen is the cap will fuse to the stem and then you have a problem.
I believe using a anti-seize compound would stop that.
Jeez...24 posts about valve stem caps. A little OCD, are we? Go to Autozone and buy a set...they cost about $2. Problem solved.
Cooldude01
20
10-26-2017 04:12 PM
Skier4lyfe303
07-13-2016 03:53 PM
