service code
Old Jun 29, 2025 | 09:08 PM
vile10's Avatar
service code
I have a rookie question - when the car shows a service code, does it really have a sensor that reads the fluid being low or its just by milege or timeframe?
e.g. I know the oil is probably a sensor since it almost always comes on when it's 15% but what about transmission fluid or brake fluid or differential fluid?
Old Jun 30, 2025 | 07:05 AM
Clickit02's Avatar
Engine oil life is not determined by a sensor but by a calculation based on mileage, number of starts and stops, driving style, etc. The change intervals for other fluids are determined the same way.
Old Jun 30, 2025 | 07:43 AM
mrgold35's Avatar
mrgold35
Some items are determined by the vehicle owner:
- one year max on engine oil if you don't get the M.I.D. notification within 12 months
- brake fluid 3 year interval (newer Acura's have a code for brake fluids)
- spark plugs at 100,000 miles
- serpentine belt (usually done at timing belt service at 100,000 miles)
- Timing belt, code pops up a +/- 105,000 miles; but, many owners change out the timing belt in the 7-11 year time frame if they are under the 105k mileage (can include serpentine belt since that needs to be removed for TB)
- water pump, can done at Timing belt service to save on labor cost
- AT/transfer case can be done early without M.I.D. notification if you tow a lot (near max weight, hilly terrain, stop/go traffic, most travel includes towing, etc...)
swttsx007
3G RDX (2019+)
Apr 29, 2023 02:12 PM
drekman
3G RDX (2019+)
Apr 12, 2023 11:57 AM
amgates80
Apr 17, 2020 11:52 AM
Jaspal Singh
Nov 13, 2017 01:26 PM
Comfy
Nov 16, 2015 04:30 PM
