Parking sensor 'beep' volume?
Old Apr 9, 2016 | 10:56 PM
Nominee's Avatar
5th Gear
Is there an option to adjust the parking sensor warning volume? I find it a tad quiet.
Old Apr 15, 2016 | 11:09 AM
ceb's Avatar
ceb
I suspect there - just like the Acura accessory sensors, but it isn't software based. On the accessory ones the volume is adjusted on the module itself, so it is a trip to the dealer.
See the last page of the installation instructions
http://acura.bernardiparts.com/Images/Install/2013_TSXWagon_BackUpSensors_BII13471.pdf
Old Apr 15, 2016 | 01:13 PM
Nominee's Avatar
5th Gear
Thanks for this! Will check with my dealer, not sure I want to pull apart the panels to find the control units.
Old Apr 15, 2016 | 02:38 PM
ceb's Avatar
ceb
You don't want to do this at all. It may be in a different location and may not even have a volume control.
Just go to the dealer and tell them that the volume is too low.
Old Mar 23, 2017 | 01:37 AM
computerwizard56's Avatar
Anyone found a solution? I couldn't find anything in the settings menu for this. The sensors are way too quiet with music at a modest volume of 5 even.
Old Mar 23, 2017 | 08:28 AM
chickdr's Avatar
Did you read the thread? It looks like you have to adjust the volume on the control module. No adjustments available from the drivers seat.
Old Mar 23, 2017 | 10:40 AM
Of course I read it. The responses were just not that definitive. The document posted is for back-up sensors on a TSX. I was asking if there was new information that someone might know for the RDX specifically.
Old Mar 23, 2017 | 02:11 PM
chickdr's Avatar
I don't see any suggestion our RDX is different from what is used in the TSX. Very likely the exact same system and adjustment method.
fafpak
60
Mar 15, 2021 11:42 PM
MikeRadio
5G TLX Problems & Fixes
18
Apr 18, 2016 01:32 PM
