Low Oil Indicator Light??
U said u go 10k miles before oil change
how many miles over do u go when the mid says it time for oil change
Everyone has their opinions on when you should get oil changed and what type of oil
to really find out you should take a sample of the oil and send it to Blackstone to get it tested and they’ll tell you if the oil is still good and still protecting your engine
https://www.blackstone-labs.com/
to really find out you should take a sample of the oil and send it to Blackstone to get it tested and they’ll tell you if the oil is still good and still protecting your engine at them miles
As far as how far beyond the "Maintenance Minder" this 10k comes about, to be honest I don't know. I usually take note of the code in order to address the other possible things that should be serviced at that particular time.
I have never done the Blackstone process but have known about them for years now.. Based on all the reports I've read on Bob is the Oil Guy, it appears that 10K is a non issue as a general consensus.
I'm convinced that every source of information is at least somewhat corrupt and sometimes innocent ignorance interjected. We really need to discern when we are trying to gain knowledge.
"I have had my RDX for about 2 years now. I change the oil in this vehicle according to the maintenance minder, and while I am currently at 30%, I have only changed it twice in 20,000 or so miles."
I have historically changed my oil at (roughly) 10,000 mile intervals, although I have gone as far as 10,800 miles. This RDX is the only car I have owned with a "maintenance minder", so after finding that it is not simply a mileage counter, I decided to give it a try. I changed the oil shortly after I bought the car and reset the minder. I have changed the oil once since then, and am at 30% currently. I will change it again when I am at 15%.
RFT!!!
Dave Kelsen
I walked into a bar the other night and ordered a double.
The bartender brought out a guy who looked just like me.
RFT!!!
Dave Kelsen
I'm not crazy, I've just been in a very good mood for 30 year
JS2194, the OP, uses Mobil 1 Extended Performance oil & filter. 10k OCI is not an issue. That combination can easily go 15k miles......as long as the engine is not burning oil (which is not an oil issue). Giving his attention to maintenance, I'm pretty sure JS2194 is on top of this.
Nor have I. I think it would be a very rare occurrence indeed to have an oil related failure in an engine with the proper level of oil in the crankcase and a good filter installed.
However, I have 2 different friends who wound up replacing engines because their adult kids (1 male, 1 female) either didn't know how to check the oil level or simply ignored it...and then ignored it when that red oil symbol illuminated on the dash.
. Both were good vehicles, but had >100k miles on the odometer and consumed oil.
What’s everyone’s opinion on Amsoil signature series oil for our 09-14 TL’s ?
I have 14 3.5 for 3 years now and I’ve been using Amsoil for last 2 years w Honda oil filter
i change my oil & filter every 4K miles since i drive more than 80% city driving with little highway miles
Thxs in advance
Thxs in advance
My opinion is you are overpaying for your oil. There are many other oil options for about a third of the price of Amsoil that will protect your TL well. Especially with your OCI. As long as the oil meets the require API oil ceritfication and viscocity for your vehicle, you're fine.
We get caught up in the "more must be better" game with automotvie fluids thinking they will somehow protect our engines better. The key is you are on a regular OCI using a quality oil. A quality oil is one that meets the required API oil certification for your TL.
I always got a chuckle from some members on a motorcycle forum talking about engine oils ad nauseam as if they had a lab to test them, and then they look for the cheapest oil filter they can buy. And even the latter, all you can do is comment on the build quality because I also do not have the lab facilities to test filtration qualities either. We used to have those facilities at work including oil analysis.
Talking about microns? There is more to it than that.
