Interior lights do not work
Old 06-29-2012, 11:24 PM
4th Gear
dblackwood's Avatar
Bought a FWD w/ Tech the other day and I realized the next day that the interior lights do not come on when the door is opened. The ceiling light in the rear will also not come on when sliding the switch to "on".
Also, is there any lights in the front that should come on when the door is opened, i.e. map lights? The door lights do illuminate.
Am I missing something or do I need to go back to the dealer and have this looked at?
Old 06-30-2012, 07:14 AM
madrye28's Avatar
There should be 3 settings. "Off", "Door", and "On". Make sure all lights are set to "door". Also, Check to make sure its programmed correctly on your trip computer. Go to "Customize Settings" Refer to owner's manual if needed. If that doesn't work then call your dealer and they can take care of it for you. When the car arrives at the dealership from the factory, all lighting/electrical is off and disconnected, they may have forgotten to turn the interior lights on prior to delivery. I doubt the fuse is blown on a brand new car, lol.
Old 06-30-2012, 07:23 AM
Hugh 27's Avatar
OP, above the passenger seat, next to the sunroof controls is the switch. That was probably in the off position. It's a separate switch, i.e. not on the lights themselves.
Old 06-30-2012, 02:06 PM
4th Gear
dblackwood's Avatar
That was it... thanks!
Old 06-30-2012, 06:40 PM
Car Crazy for Sure!
Colorado Guy AF Ret.'s Avatar
Just saying....folks, this easy stuff is in the manual. Please take the time to look through it, you'll be amazed at what you might find out. I still haven't read it all yet....or the Nav. one.
Old 07-01-2012, 11:55 AM
hawkeye62's Avatar
Reading the manual can be a real PITA! BUT, if you download the pdf manuals, you can use the Adobe reader to search for words or phrases. Much easier.
Good luck, Jim
Old 07-01-2012, 10:53 PM
Car Crazy for Sure!
I know Jim, I have it all downloaded in pdf files. It's whatever is easiest for each person....but, everyone has the Manual.....some may not be able to download those large pdf files. Just thinking.
02-25-2020 09:57 AM
wusty23jd
09-24-2015 11:41 AM
acurajj
09-19-2015 03:47 PM
drewdeezy03
09-03-2015 08:04 PM
Quick Reply: Interior lights do not work
