How to test refrigerant pressure?
Old Aug 14, 2019 | 12:07 AM
truelies's Avatar
2013 RDX driver side warm air, not cool. Air mix motor is working, click sound, so I think the problem maybe lack the refrigerant.
Old Aug 14, 2019 | 12:08 AM
Only the driver's side? How about the passengers?
Old Aug 14, 2019 | 12:14 AM
truelies's Avatar
passenger's side getting cool air, not sure if it's cool enough though.
Old Aug 14, 2019 | 11:33 AM
markAZ's Avatar
To do it right, you'll need a set of gauges and know how to connect them and interpret the results. Messing with A/C systems can be dangerous...if you don't know what you're doing you can do a lot of expensive damage to your A/C and possibly some painful damage to yourself. Take it to a good shop and get it done right.
Old Aug 14, 2019 | 11:42 AM
truelies's Avatar
I think just go to auto store and buy this, to refill some r134
https://www.carcarekiosk.com/video/2...recharge_freon
Old Aug 14, 2019 | 03:19 PM
dave08902's Avatar
Here is the A/C system test from the factory service manual
File Type: pdf
Old Aug 14, 2019 | 04:13 PM
egads's Avatar
It is a pretty common failure of the blend doors on these Honda/Acura vehicles with two zones. I would look at that before jumping to refrigerant level.
Old Aug 14, 2019 | 04:58 PM
truelies's Avatar
How to check the blend door? Is this same as air mix motor?
Old Aug 15, 2019 | 01:22 AM
egads's Avatar
I'm sorry, I don't know on this vehicle. I looked for threads about it. You can look at MDX threads. I did look at threads over on the Odyclub and it is possible low refrigerant
can cause the the difference in temps from one side to the other. I would open the link dave08902 posted above and go through the troubleshooting steps.
blibbertibs
3G RDX Problems & Fixes
39
Oct 9, 2019 10:58 PM
khwilm
Jul 19, 2018 10:09 AM
ferezzom2
4G TL Problems & Fixes
Aug 11, 2017 02:46 AM
maceio4
1G RDX Problems & Fixes
Jul 11, 2015 01:14 PM
types1967
May 30, 2003 10:48 AM
