HID Lights:
Old Dec 26, 2013 | 01:15 PM
DealsAllTheWay's Avatar
HID Lights:
I have the tech package therefore the HID lights. I am just wondering why when I look at the Q5, Cadi SRX, BMW X3 the HID lights appear more blue.
When I first start the car, the light appear to have more of a bluish tint and after a couple of minutes it's not as blue..
anybody follow me here??? or am I crazy?
Old Dec 26, 2013 | 02:11 PM
weather's Avatar
^^ You are correct and my TL and RDX do the same....starts off bluish then turns more "white" after a while. I did see an MDX the other in my subdivision and there are no street lights so the MDX was illuminating the entire area and it had a nice look to them. Different color, almost had a purple tinge to them....
Old Dec 26, 2013 | 02:29 PM
Acura's have one of the best HID systems, and yours do seem to have a bluish tinge to others while maintaining a clear visual white color for the driver
Old Dec 26, 2013 | 05:54 PM
YeuEmMaiMai's Avatar
same here on 02 CLS blue when first on and white within a few seconds...
Old Jan 2, 2014 | 01:04 PM
have you seen BMW or Audi's lights? They seem bluish from any angle...that's what I was referring to
Old Jan 2, 2014 | 03:25 PM
ceb's Avatar
ceb
BMW, Audi and most Japanese use 4300k HID bulbs. Mercedes recently started with 5000k bulbs but the "blue tint" is an illusion.
Old Jan 2, 2014 | 03:36 PM
what K is Acura?
Old Jan 2, 2014 | 03:43 PM
weather's Avatar
Acura uses 4300K too....don't quote me on this but the color will "shift" a bit after several hours of use, say 300h of use or so.
Old Jan 2, 2014 | 04:31 PM
dmaxv8's Avatar
they are blue when they first start as the arc has to warm up to get to the correct color -temp. the more color (blue) = less light
Old Jan 14, 2014 | 01:55 PM
KJW73's Avatar
2014 RDX Tech AWD
The HID light color will eventually change (as someone reference above) and will get somewhat dull after many YEARS of use. I just traded in my 05 TL Navi (bought new in 05) and only needed to replace the HID bulbs once in 9 years - I don't think that's too bad. And you'll definitely know when they are going out: they will become dull with a bluish/greenish tint; then at some point shortly thereafter it will just blow. Not sure if the RDX takes the same type of HID bulb that my 05 TL had, but if so the bulb retails for $99.99 (at PepBoys) plus dealer installation (because of course, Honda's design requires you to take off the entire side panel to replace - thus, a dealership visit at least for this chick!).
Old Jan 14, 2014 | 01:57 PM
Most modern cars today, require some sort of bumper removal to reach the head lights.
Old Jan 14, 2014 | 01:59 PM
thephantom's Avatar
If you like the blue output, you can always replace the bulbs with something that has a higher temp (K).
Old Jan 14, 2014 | 02:03 PM
but why would you want to lose lumens( brightness) ?
the higher up on the Kelvin scale, the less usable light you will have, straining your eyes at night and making it hard for you to see in the rain.
Old Jan 14, 2014 | 02:05 PM
thephantom's Avatar
I wouldn't, but some people like the blue-ish look. To each their own.
BTW, someone mentioned the MDX lights; those are super bright LED's but I don't really love the color. I had a RLX for a loaner a few months ago and the jewel eyes lit up the road like no other, but the color was something I had to try to get used to.
Old Jan 14, 2014 | 04:12 PM
dmaxv8's Avatar
the good news you don't have to remove much to change the light bulbs on a 2014 rdx I did the drl- hi's with no removal the hid's you might have to remove the battery. it depends on how small your hands are.
Old Jan 15, 2014 | 10:14 AM
5 Acuras's Avatar
Make it #7!
What did you replace the DRLs with?
Old Jan 15, 2014 | 03:51 PM
my 02 CLS has 12+ year old bulbs they are still plenty bright but think about it this way
halogens (good ones) run about $20 to $30 a pair and you will have to replace them every 2 to 3 years on average so in the end you pay about the same....
Old Jan 16, 2014 | 04:31 AM
KJW73's Avatar
2014 RDX Tech AWD
Absolutely agree about the halogens. Probably the reason that my TL's HID bulbs went out is likely because I had them on all of the time (on Auto)? LOL.
Old Jan 16, 2014 | 06:22 AM
^ I run my lights on all the time but I rarely do short trips. I will most likely replace my bulbs this year along with my driver's side headlight...
Old Jan 19, 2014 | 09:50 PM
Timmy18's Avatar
My TSX's are almost completely green but momentarily blue upon start up, thanks to condensation. >
Icky.
Old Jan 23, 2014 | 10:41 AM
Icky.
ya, I have noticed lot of acura's get that plastic pretty smoky...condensation maybe an isolated issue...take it to your dealership to make sure it's sealed properly
Old Jan 23, 2014 | 09:38 PM
dc5k20z1's Avatar
You could try swapping your bulbs for Osram CBI (clear blue intense) 5000k bulbs available from theretrofitsource.com for a more white blue hue output
But the actual blue color you see from other cars is probably associated with the HID cutoff
Old Jan 24, 2014 | 08:40 AM
Icky.
check you seals at the ballast and headlamp
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
