Fuse issue?? Please help
Old Oct 8, 2016 | 02:15 PM
Zack Gil's Avatar
5th Gear
I have a rdx 2015. I wanted to convert my low beam halogen headlights to hid. Per directions, I needed to disable drl fuse and do I did. I took out the low beam fuses. When I did that, obviously I couldn't turn them on, but now, I put the fuse back in for both left and right sides, and now the headlights don't turn on anymore. That is with the ordinal factory installed bulbs. I put the fuses exactly where they were located originally. Can anyone help?
Old Oct 8, 2016 | 02:51 PM
charlie65's Avatar
It's a possibility you may have compromised the fuses when you took them out. Take them out again and do a continuity test or take them to an auto-zone/napa/pepboys/oreilly store and have them test them for you.
Old Oct 8, 2016 | 03:43 PM
Zack Gil's Avatar
5th Gear
Tale them all out it just the once I played with
Old Oct 8, 2016 | 05:47 PM
Comfy's Avatar
2014 RDX AWD Tech
I presume take out the only ones which you fiddled with.
Now are you planning to get HID bulbs into the halogen reflector or are you retrofitting an HID projector? Someone had to ask this question : D.
Old Oct 9, 2016 | 11:30 AM
ceb's Avatar
ceb
...and this is why I didn't post in this thread.
Old Oct 9, 2016 | 12:08 PM
Zack Gil's Avatar
5th Gear
I called few shops and they told me they don't even know if there's any type of mechanism that tests fuses. Am i losing my mind or what?I just want to convert everything the way it was am not touch any thing else
Old Oct 9, 2016 | 04:01 PM
charlie65's Avatar
Here:
https://www.walmart.com/ip/Littelfus...-MINI/41349452
Old Oct 9, 2016 | 04:10 PM
charlie65's Avatar
or here:
Electronic Specialties ATC Fuse Buddy tester ESI306B- ReadReviews onElectronic Specialties #ESI306B
Digital Multimeter - Save on this 7 Function Digital Multimeter
Old Oct 9, 2016 | 04:23 PM
charlie65's Avatar
Littelfuse Blister Pack 097019BP - Fuse Tester/Puller | O'Reilly Auto Parts
Old Oct 9, 2016 | 04:30 PM
Zack Gil's Avatar
5th Gear
Ok, I got it to work after resitting the fuses. The instructions to convert halogen to hide to pull the fuse. Does that even make sense? How could I make this work?
Old Oct 9, 2016 | 04:44 PM
Stick to halogen
Old Oct 9, 2016 | 09:56 PM
CrimsonElan's Avatar
If you don't know how to test a fuse's continuity, you probably should not touch your car's electrical system.
Old Oct 9, 2016 | 11:59 PM
http://lmgtfy.com/?q=How+to+test+a+fuse
Old Oct 10, 2016 | 08:54 PM
Comfy's Avatar
2014 RDX AWD Tech
Ok guys. That's funny. He simply asked a question.
To the OP. Your car's wiring is optimized for halogen bulbs so let be that way. If you really need to install HID in your car with some amount of safely and avoid the cops, you should do two things.
1) Retrofit an HID projector into your car headlight housing (cheap way) or buy an HID version of headlights (will cost more)
2) use an external wiring harness straight from the battery so that you are not taxing the existing wiring of the car. If these do not sound appealing to you (time, money and effort wise), you should stick with halogen lights.
Even after doing all these modifications your car will still be technically illegally modified but may state pass state inspections and avoid cops. I think the best and safest procedure is to trade your car for another with tech / facelift model. Good luck.
Old Oct 11, 2016 | 09:05 PM
ceb's Avatar
ceb
I taught you well. My work here is done.
Old Oct 13, 2016 | 05:31 AM
Comfy's Avatar
2014 RDX AWD Tech
I don't generally pay attention to internet likes, but coming from the mighty Ceb, I'll take it. You made my day. Thank you.
nonger
Oct 9, 2016 04:45 PM
ILX24
Sep 24, 2016 05:55 PM
hypnotiq1
Aug 1, 2016 08:27 PM
unnamedny
ILX
18
May 9, 2016 08:19 AM
TL_Trooper
Jan 9, 2016 11:25 PM
