Flush Brake fluid?
Bleed each caliper; until you see fresh new fluid. once you've seen new fluid, you've effectively "moved" all the old fluid out
I was using the word flush as a verb.
the article you linked says the SAME thing I did...it used "flush" as a verb. or an action.
Like ALL cars you Bleed each caliper until you see fresh fluid....
A mechanic might recommend a total brake system flush, which is what I believe the article you cited was talking about. That's typically unnecessary and would involve completely bleeding the system as well as the ABS which is almost never needed.
However, a simple bleed and refill of the system which justn described is pretty par for the course for most any gearhead that decides to change his own brakes. Since pads and rotors last quite a while, I always bleed the system when I change them. We're talking like, every 60k-80k miles or so. Not exactly a routine maintenance item that you'll be doing every 3 months. I've put about 100k miles on my car and I've done it once.
It's nothing more than loosening up the bleed screw on the caliper, placing a container under the caliper to collect the old fluid, pressing on the brake pedal a few times, refilling the reservoir and repeating. I'd say you'd use a full container of brake fluid to do all four. It takes all of 30 minutes and $10 for a bottle of brake fluid. If it's your first time, maybe an hour. Just make sure not to allow the reservoir to get too low between pressing the pedal when bleeding otherwise you'll get air in the brake lines and have to do a lot more "bleeding" in order to flush out all the air.
That's it. Is it necessary? Probably not. But old fluid can have air, water and contaminants in it that reduces its "compressibility" which in turn results in a more spongy feeling brake pedal. The feeling of new rotors, pads and brake fluid is like driving a new car off the lot with brand new brakes.
Ha. Uses an old soda bottle. That's exactly how I collect mine
Oh yeah, OP, you don't want to get brake fluid on your paint. It can mess up clear coat. So be careful when you're filling the reservoir as well as collecting the old stuff out the caliper bleed screw.
I use a vacuum device , that I hook to the bleeder, then turn the bleeder to open and hook the vac, while the cap is off of the master cylinder. It pulls the fluid out at the bleeder, than refill and head to the next wheel.
Sears.com
Sears.com
Sorry to be pedantic...the engineer in me just can't resist correcting...
(*) Technically, all fluids are somewhat compressible but hydraulic fluids like brake fluid are very nearly totally non-compressible whereas air and water vapor are highly compressible.
Uh, no. It's actually the opposite. Air in the system increases the "compressibility". Brake fluid is not compressible(*) but air is. It's the air that makes brakes spongy and why you have to remove the air when you open the system. Also, brake fluid absorbs moisture which can lead to corrosion of the brake components (calipers, etc) and can also turn to steam if it gets hot enough, which is also compressible and can make the brakes feel spongy. I agree, tho...even if the brakes don't feel spongy it's a good idea to flush them periodically.
Do I need to flush the brake fluid? Here it says never flush https://bottomlineinc.com/life/car-m...-kind-of-flush
My last car that I bought new and owned for almost 15 years is now owned by a friend of mine and it is in its 19th year of very harsh winters. The brake calipers are still original. I would flush the system every 3 to 4 years. It also helps the bleeder screws from getting seized.
I use a Motive Products Power Bleeder to do mine. Best tool I ever bought.
Motive Products
Carbon Legend
Nov 25, 2016 01:50 AM
