DIY Ceramic Coating
Old Apr 14, 2019 | 10:43 PM
Comfy's Avatar
2014 RDX AWD Tech
DIY Ceramic Coating
I'm sure someone must have done DIY ceramic coating on your 2G RDX. I've been recommended these products www.R1coatings.com and GTechniq Ceramic Coating from other subforms.
Are these the same as C quartz/ Opti-Coat which have been on marked for several years now.
I'm interested in only reducing my car wash / maintenance frequencies and not aiming for a showroom shine. I'm not particularly bothered to do professional coating (as several members prefer) simply because paying over a grand for exterior coating is not what I consider prudent for a five year old car. I usually park the RDX outside in my driveway. I'd love to hear your opinions. Thanks.
Old Apr 15, 2019 | 07:36 PM
ceb's Avatar
ceb
Your results will only be as good as the prep. You need to clay bar and polish the surface prior to application. Anything on the surface will be there forever after the coating is added.
The coating needs to be applied lightly AND evenly. Any streaks will also be there forever.
If you've not done the prep before and feel comfortable making your car better than showroom perfect, then you won't be happy with the results - no matter how low your standards as the coating will amplify any paint defects.
Old Apr 19, 2019 | 01:15 AM
Comfy's Avatar
2014 RDX AWD Tech
I will do the prep as required with clay bar and polishing as advised. But I don't have a special tools such as buffers for this job and will do whatever can be done by hand. Is it a one man job or you need multiple people?
Old Apr 22, 2019 | 01:55 PM
2015RDXTech's Avatar
Depending on how good you want the car to look, I wouldn't be surprised if it took you a whole day to do the job. Polishing this kind of paint pretty much requires a buffer of some sort, which also makes it a lot easier and faster. I would get a cheap DA polisher and get a friend or someone to help you out if you don't want to spend a whole day on it.
Old Apr 25, 2019 | 05:02 PM
Tech's Avatar
So is this product also applied over Xpel paint protection film?
Coolguy
3G RDX DIY & FAQ
19
Dec 21, 2019 09:33 AM
StreetKA
Apr 27, 2010 11:17 PM
snowman81
Feb 22, 2007 09:40 AM
ayougo
Dec 5, 2005 10:28 PM
ayougo
Nov 24, 2005 01:28 PM
