Clunking from rear
#241
I wouldn't mind buying my own quality shocks. So far, I can't find one after market shock company that makes one for the '13 RDX. The one for the '12 RDX sounds like a "maybe" deal. Most know...but, maybe not all, that the suspension on the Gen 1 RDX's was a lot stiffer and made for carving canyon roads. So, I can see where these would ride "harder" than they should for our suspension systems.
It would be good to hear feedback after you do some winter weather driving. I'm hoping that a shock company comes out with quality replacements soon. KYB is a good shock. And affordable.
The factory shocks were a good idea on paper...and maybe still are..but, the construction by Sachs is apparently not up to what the drawing board "said."
Their "2 piston valves" shock seems to have the #2 valve set too "harsh" and thus causing our noise problems. The idea was to have that valve help stabilize larger suspension motion for increased stability. Valve #1 is designed to handle "softer" type of road vibration and bumps.
High quality after market shocks use a different system to do the same thing. Their shocks just stiffen the more they are compressed by use of their oil system and bypass methods.
I would have preferred to go with Bilststein shocks but KYB is the only manufacturer of replacements for the 2012 and older RDX at this point in time. Could be another year or two before we see anything for the 2013 and newer models.
Aside from the shocks there's a lot to like about this vehicle.
#242
Car Crazy for Sure!
The KYB's are firmer but not objectionably so. I'll definitely report back after the weather gets colder.
Stupid Motor Trend...just came out with their testing for SUV of the year. Didn't have the MDX as a "finalist." Why?? Pretty much they didn't like the "busy" center stack, etc. They praised how quiet it was..more than the others....how it rode.. great performance..on and on. But, it's not a finalist?? Give me a break! It's a much better vehicle than some of their finalists. They must be Democrats!
#243
^^ I agree with both of you....the RDX does more "+" than "-" but teh problem is that it is such an unacceptable noise problem and something so simply that I think this is what is causing my biggest grief. I wish we could all call Sachs and voice our disgust in their dampers....
#244
Summer is Coming
I'd like to think Acura cares but we're 2 years into this and they have no solution? There are 2 possibilities... either they don't care to fix it, or they can't fix it. They seem to have done some ineffective change in the part but that hasn't worked. So the conclusion so far is that they cannot fix it. If it were my car and I were having these problems I would have gone after market. The cost is too little to suffer the aggravation.
#245
#246
Car Crazy for Sure!
I'll repeat what I've talked about before on here...yes, the shocks could be better. But, this is not a deal breaker....for most owners I see here. Jumping ship for this is not an option for me and many others. Why?.....because the long list of "good" outweighs the "bad" with the RDX. Compared to other vehicles...price for price what you get...etc, this is one fine SUV. There's not a vehicle out there that doesn't have "some kind of issue" the keeps it from being perfect. And perfect will never happen.
The noise from these harsher shocks....seems to be from the cover of the spare...and some fenderwell panels that meet up with the metal body.
The "love" for this RDX far overcomes the shock issue. It's not like the trans is falling out, etc. Is it "right?" No...we need a better shock. But, until that happens I can certainly live with it...not so terrible....until new ones come around. They are not leaking...I've checked twice. If they were I'd have my dealer replace them.
It always amazes me how some folks can almost seem to go ballistic over something that is not a major issue. It's an "issue" that needs correcting...but, it's not the end of the world. I don't lose any sleep over it. Some on here LOVE to extort the issue to the highest degree....then others get all worked up and want to immediately trade their RDX for a "better SUV." Pretty silly. Yes, each to their own...I get it....but, common sense has to come into play...and unfortunately that is something very few people have. This is all IMHO of course. If the shoe fits...as the old saying goes....wear it and be happy.....or not!
5 Acuras (04-04-2014)
#247
I drove around with the back half of the car disassembled and still the noise. It wasn't until I replaced the shocks that the noise went away completely. I hate rattles and noises that sound like something calamitous is about to occur be it imagined or otherwise.
#248
I too thought this was the case and spent the first 2-3 months of ownership checking every panel, screw nut and bolt etc to try and locate the source of the noise, only to confirm the noise eminates from the shocks.
What's even more disturbing, Acura is claiming that this is a "NORMAL CHARACTERISTIC" of the car.
#249
Car Crazy for Sure!
With all due respect...shocks don't make the banging sound like a loose sheet of plywood. Their lack of ability to soften certain road conditions causes the body components and whatever is "loose" to make the sounds we here. I have easily found noisy inner liners loose enough to bang against the sheet metal. The sound of a totally "blown out shock" is distinctive...and the sound we all are hearing is caused by the shock...not the shock itself.
That's my take and I'm sticking to it! LOL! Derived from way too many vehicles owned and my auto and technical background.
#250
Put it this way, if this noise were happening on a brand new Chevy, we'd be killing them for it.
I'm not saying this is a watershed event in Acura's history, but ultimately they can't just trade on their reputation for quality, they have to earn it.
#251
involved, just the truth.
The attached document does a good job of explaining what it is we are hearing and what causes it.
The following 3 users liked this post by hand-filer:
#252
Summer is Coming
I can only speculate on what I'd do. If it is a lease you could still replace the dampers and then put the OEMs back on when you return it at the end of the lease.
OR...
Wait for Acura to figure this out. I can't say they are exactly impressing anyone with their mastery of dampers. However they have certainly mastered the art of shining on their customers.
OR...
#253
Just came back from the Acura dealership today. Had all the shock absorbers/dampers replaced on vehicle with brand new ones under warranty. Clunking noise has gone away completely and the car drivers very smoothly again. I guess I'll wait and see how it holds up especially during the winter months. Will keep you posted.
#254
How were you able to "duplicate" the noise?
Did you ask what was wrong with the ones they replaced? Were they leaking...?
#255
I didn't go with them for a test ride but they did determine that the shocks were "faulty". They didn't say which ones exactly but they did hear noises from both front suspension and the rear. So they ended up replacing all 4 shocks/dampers. Crazy if you ask me that Acura couldn't get it right the first time. Anyhow, hopefully these ones will hold...this is the second time going into them for this issue.
#256
One Month Update
-22C this morning and -18C at present. The car is still noise free.
With the colder weather and subsequent higher viscosity of the shock fluid I am experiencing a siffer ride as is to be expected.
Overall I'm satisfied with these shocks and can live with the slightly firmer ride. I feel it is a fair trade off compared to the "sounds like it's falling apart" noises produced by the OEM shocks.
And so it will remain until Honda acknowledges there is an actual problem and issues a recall. I won't hold my breath waiting for that to happen.
Cheers!
hf
weather (12-07-2013)
#257
My 2014 RDX with 2600km on it has clunked in the rear from day one. It's only during sharp, short hits, and not a bottoming out issue, rather when a quick transition is required.
It actually annoys the heck out of me and makes what should be solid tight ride feel like an econo box ride...
Generally the ride is smooth overall, but its has these moments when....
#258
hand-filer....I may follow your direction and install the rear shock of the 2012 RDX and get rid of these. I will talk to my dealership and what they will do for me....Thanks for experimenting and providing us with an option. I am not sure why Acura doesn't recommend their dealers to install a different type of rear shock over trying to solve what is wrong with their OEM rear suspension.
#259
#260
The shocks will not alter or interfere with the way the traction and stability control systems function. The valving is not that different from the factory shocks.
The KYB's are a single stage mono-tube design and provide a nice controlled ride. They are firmer on smaller impacts and similar on larger impacts.
My impressions are subjective so I can't provide you with measurements or percentages.
I like the noise free ride. The vehicle handles great.
In comparison my brothers 2011 Chevy Equinox rides like a tank and he would be the first to agree.
h-f
#261
And the sad thing is his hands are tied because he's dealing with cars under warranty so he doesn't have the option of experimenting with aftermarket parts. He did request the part number of the KYB's from me so who knows for sure. I'll quiz him for more information when I'm in for my next service.
Cheers! h-f
#263
Last winter I had the clunking which was driving me crazy. With the warm weather over the summer the noises dissipated, but I expected them to return this winter. Fortunately, they have appeared. The suspension isn't as quiet as I would like, but the clunking seems to have worked itself out. Perhaps they are broken in now.
I also test drove an MDX tonight. I listened for the clunking and it is there too, but to a lesser extent than the RDX was new. Acura is likely using the same parts manufacturer and this issues is found with the ILX, RDX, and MDX.
#264
My wife took the RDX to the dealer Thursday. They were able to reproduce the noise. They tried tightening things down to no avail. They refused to replace the dampers because Acura does not recognize the dampers as a problem and will not reimburse them for the repair under warranty. Looks like my first Acura will be my last. I will visit the dealer tomorrow.
#265
My 09 RDX with tech and 92000 miles has been making left rear wheel clunk on rough roads for some time and it's getting worse.
Now that i've read thru most--but not all--of the pages on this topic i have two questions:
1. Do both rear struts need to be replaced at the same time, or will only the noisy one suffice?
2. Anyone have a cost guess for dealership repair?
Thanx and happy new year.
#266
I'm a dude you reprobates
rafitz (01-08-2014)
#268
hand-filer....Thanks for the update. Now you really have me wanting those 2012 RDX shocks on my RDX!!
Arctic Vortex...(lol) I love how the media eat this stuff up and really like to hype things. As a meteorologist, nothing worst than seeing these "wanna-be's" through all this technical terms all over the tv....
#269
Took the RDX to the dealer to listen to the rear chatter last Thursday. The temperature dropped to the low 20s (Atlanta) and the rear became dead silent. Drove to Charlotte NC that afternoon and by the time we got to Charlotte the temperature was back in the 30s and the rear sounded like a bag of bolts again. Totally frustrating.
#270
Shocks are once again functioning like they are supposed to.
#271
So my RSX is in the shop for some repairs (the rear hatch struts need replacing) so they gave me a 2014 RDX loaner for a few days. Kona color AWD w/Tech! Having been a member of this forum since summer 2012, the FIRST thing I did when driving was turn off the radio and start listening for clunking in the rear. I heard nothing? I even found myself trying to hit potholes in order to create the clunking everyone complains about. However, I hear nothing.
Maybe driving an RSX (which you hear and feel EVERYTHING) has numbed me to noises? But I feel the vehicle is incredibly quiet and soaks up bumps just fine. So am I numb to these things?
On another note, I had removed the RDX from my list of vehicles to purchase in the Spring... but after having this loaner, it's back on the list. Very nice ride, but the GPS is terrible and a waste of money. Wish I could get the HID's and power liftgate as separate options.
#272
#273
Hey Guys,
Still using OEM replacement shocks and still no noise/clunking sounds. They were replaced since November 2013 and I've dealt with minus 30 degrees Celsius temperatures. So far so good...will keep you posted.
#278
Greetings all! New to these forums, (as we just purchased a new 2014 RDX in January). Thankfully this tread exists, as we've been going nuts over the clunking noises coming from the rear suspension. I would especially like to thank 'hand-filer' for his methodical approach and persistence in documenting and fixing this issue. I can confirm several things from what I've experienced and read in this thread so far:
- Yes, 2014 RDX's are just as prone to the rear-clunking sounds from the rear suspension
- The dealership, (Erin Mills Acura, Ontario), is not aware of any "new" or "revised" rear strut assembly
- We had both rear struts replaced already which didn't solve anything
- I have Acura Canada involved and filed a formal complaint; they've been polite, but we haven't gotten that serious yet, (they want me to bring the RDX back to the dealer to further "diagnose" the issue).
I plan on bringing some of the material listed here in this thread to the Dealership, more to assist, not to "prove them wrong". (Trying to be diplomatic). I'm sure there hands are tied as there is no formal recall or anything yet.
Hand-filer, (or anyone else who has dealt with this issue), do you think the dealership would be open to the suggestion of replacing the rear suspension to the 2012 RDX OEM struts? Or at the very least 2012 RDX OEM bushings? Was this a direct replacement, or were modifications required to equip the 2012 parts?
I'm sure there just going to auto-replace the rear suspension again with 2014 OEM parts, any suggestions?
#279
I would think that a sympathetic dealership would install the 2012 shocks on your vehicle. Unfortunately it would be an out of pocket expense for you because they couldn't do this under warranty.
The 2012 shocks are a direct replacement (I used KYB Part # 349095 More Info ). The top rubber bushing from the 2012 shock will not eliminate the clunking or loose load of lumber sound but possibly might reduce the thumping resonances.
My recommendation would be to replace the entire assembly.
Kudos to you for contacting Acura Corporate. I wish everyone with this issue would do likewise.
#280
Hey Dark Chrono,
Not sure if I'll have enough time to order the KYB's (yet), so I'm going to start with the 2012 OEM shocks for now, depending on how they react to the suggestion.
At this point, spending the extra $$$ to prevent repeat visits seems more practical. Who knows if Acura will formally address this issue...
Cheers,
