Clunking from rear
Old 09-22-2015, 12:20 AM
  #681
mdfree's Avatar
So has anyone found the new KYBs for the 2013-2015 available yet? My right rear shock is really getting noisy!
Old 12-08-2015, 11:31 AM
  #682
yuma97's Avatar
KYB 554406 from Rock Auto $63.79 plus shipping. This is the cure for clunking from the rear. KYB uses a rubber bushing on both the inner and outer body mount where the shaft attaches through the body in the cargo area. The stock (Koch I believe) does not. Perhaps this lack of an outer bushing is the cause of the clunking.
Old 12-09-2015, 11:23 PM
  #683
mdfree's Avatar
So did you replace yours? If so, can you tell if the ride is softer/firmer/same? I think the OEM is made by Sachs. Thx
Old 12-10-2015, 09:33 AM
  #684
yuma97's Avatar
Yes I replaced mine and I have noticed no difference in ride quality, the same as stock. You are correct about Sachs. Easy replacement as well especially with having access to the top of the shock in the cargo area via those removable panels.
Old 12-10-2015, 04:00 PM
  #685
mdfree's Avatar
Good to hear that it fixes the clunk without messing up the ride!
Old 12-15-2015, 08:47 AM
  #686
Sam Axe's Avatar
Did Acura fix the rear suspension issue on the 2016 model?
Old 12-20-2015, 11:15 AM
  #687
2014RDX's Avatar
Just replaced mine with the KYB's. 3rd set of shocks with just under 70K. Very easy replacement, and zero loss of ride quality. Clunking gone instantly.
My only suggestion.... if you haven't invested in a nice set of pass through sockets, do yourself a favor and get them. Made the top nut a breeze taking on and off.
mdfree (12-20-2015)
Old 01-16-2016, 12:20 AM
  #688
Spautodetail's Avatar
Wanted to say thanks to everyone in this forum. Similar issue with my ILX with same design of shock, I was able to resolve the clunk and rattles in my car beyond what the dealer could do (by replacing with the same crap design) and went and swapped for OEM civic si shocks. Rattle clunk and harshness gone instantly. So quiet now.
Old 02-23-2016, 06:51 PM
  #689
mdfree's Avatar
Getting ready to order the KYB shocks, quick question is the Rock Auto price ~$64 for two shocks? wasn't real clear when I'm on the order page. Thx
Old 02-23-2016, 07:00 PM
  #690
mdfree's Avatar
Never mind, it's $64 per shock
Old 09-24-2016, 03:51 AM
  #691
sekngen's Avatar
Just had our 2013 base come out of the dealer after they replaced the rear passenger strut. On the service receipt it says that the existing strut was leaking, so I don't know what the issue may be still because I'm still noticing the noise though when pulling right into our driveway or a parking lot.
Perhaps sway bar bushings need more grease?
Old 09-24-2016, 05:34 AM
  #692
2014 RDX AWD Tech
Comfy's Avatar
Originally Posted by sekngen
Just had our 2013 base come out of the dealer after they replaced the rear passenger strut. On the service receipt it says that the existing strut was leaking, so I don't know what the issue may be still because I'm still noticing the noise though when pulling right into our driveway or a parking lot. Perhaps sway bar bushings need more grease?
You need to talk to the dealer again. May be they didn't use the updated parts. It shouldn't be like this. Such oversight is going to hurt Acura big time in the long run.
Old 09-25-2016, 02:52 AM
  #693
sekngen's Avatar
So it looks like the one they put in was 52610-TX5-A02. I took a look at the driver rear shock and it was the same except it was A02 411 I think.
Plan to drop it off at the dealer sometime this week and have them take a look at the other side too plus looks into whatever else they think it might be.
Old 02-10-2024, 02:02 PM
  #694
9th Gear
the_head343's Avatar
This fixed the clunk on the used RDX we just bought. The part number (on Amazon) was 554406. On sale for about $88 each with free shipping as of today.
Old 02-10-2024, 02:03 PM
  #695
9th Gear
We also replaced the rear sway bar end links. I recommend the Moog brand as they were thicker links with grease fittings.
Old 02-10-2024, 02:05 PM
  #696
9th Gear
There are on sale on Amazon as well for about $18 each - 60% off! Part number K750380.
marcelft
07-10-2018 06:17 PM
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 10:16 AM
d.lim
09-15-2015 08:54 PM
1Lieutenant
4G TL Problems & Fixes
09-10-2015 08:39 AM
Quick Reply: Clunking from rear
