Adjust Tailgate Opening Height ?
Old Jul 25, 2013 | 02:31 PM
acura0614's Avatar
Hi All, is it possible to adjust the tailgate opening height on my 2014 RDX?
Can't open the tailgate when in the garage without hitting the door.
Thanks.
Old Jul 25, 2013 | 05:47 PM
GRDX's Avatar
Thanks.
No, but if you back into the garage the tailgate will not hit the door.
Old Jul 25, 2013 | 07:26 PM
Doubtit's Avatar
Never thought about it until I saw Chevy Equinox ad on TV touting their adjustable hatch. Ever since then I watch to make sure I clear.
Old Jul 25, 2013 | 09:20 PM
vbgregg's Avatar
Yeah, we looked at a Toyota RAV4 before we bought our RDX. The RAV4 had an adjustable height tailgate. I wondered why anyone would want the tailgate to stop in a lower position, since it seemed like it would be easier to get stuff in and out of the back if the door were fully open. I decided it was to accommodate people who were too short to push the close button. But after putting it our garage, I realized that the tailgate nearly hit our garage door opener bar. So that's a good reason to stop short of the full opening height!
Gregg
Old Jul 26, 2013 | 07:13 AM
acura0614's Avatar
My daughter has the 2013 Rav4, thats where I got the idea.
My garage is a tight fit with RDX parked in it. I could open the tailgate on our 2009 CRV without it hitting. Right now I have to open the tailgate when I'm in the driveway, not great when it's raining.
Thanks All.
Old Jul 27, 2013 | 05:31 AM
AmberB's Avatar
I'm a dude you reprobates
When you pull in the garage head first does the rear hatch door touch the bottom of the open garage door or the panels of the open door? If it's the bottom of the garage door you may have the option of adjusting the door opener to pull the door further back giving you a bit more room.
Old Jul 27, 2013 | 06:20 PM
Stump's Avatar
I had similar issue. Then one day i tried to open my garage door and the chain wrapped around stuff because the drive gear in the unit broke. A new gear, a new adjustment, and guess what? The garage door now opens up maybe 3 inches higher. The issue is the garage door, not the RDX. You could start by adjusting the up and down settings on the door. All you need is a screwdriver into the hole on the side of the motor unit. But some advice: a quarter turn at a time...a quarter turn can make a big difference in the door travel. A bonus is my door doesnt slam down down so much on the ground either.
Old Jul 27, 2013 | 09:45 PM
hand-filer's Avatar
This is the best advice in this thread. It's also a safer way to exit your garage this way, especially if if you have access from a back lane.
Old Jul 28, 2013 | 09:00 PM
weather's Avatar
^^^ I do this all the time. I like backing in.
Old Jul 29, 2013 | 09:43 AM
CoachRick's Avatar
Easier said than done...at least accessing the rear hatch AFTER you park. We've been moving into our new townhouse for the past week and backing in puts the rear of the vehicle too close to the wall/items on the 'inside' of the garage to be able to easily walk behind, open the hatch and then retrieve or load items into the cargo area.
Depending on your garage configuration, backing in may be good for a lot of reasons, but not for accessing the rear hatch after the vehicle is parked. I've got a piece of foam swimming noodle in the cargo area for just such emergencies...let the hatch open until it touches the foam and becomes wedged between the hatch and garage door. All will be good until your wife hits the garage door button before having the garage door in sight(Don't ask me how I know this) . For better or worse, remember.
Old Jul 29, 2013 | 12:42 PM
Stump's Avatar
Glad I'm not the only one...my wife brought down garage door on my ML300 hatch, my 2002 MDX hatch, and my 2007 MDX hatch. Just a matter of time, especially living on a corner and with her hitting the open button as she starts to make her left turn/before front of house is in sight.
Old Jul 29, 2013 | 09:43 PM
CoachRick's Avatar
We have two garage doors now vs the 'double' at the big house. I got to the point that I would put something in front of the light beam when I thought my vehicle might be in jeopardy . Much less likely to happen now; but I made sure she couldn't close the door on the front of the RDX this afternoon, since I had the nose poking out while unloading the cargo area(see above description).
Old Oct 7, 2013 | 04:38 PM
JFK-USAF's Avatar
Not sure backing in would be an option for those with an attached garage. You end up filling the garage up with exhaust fumes on start up and during back in. --- Just my opinion
Old Oct 7, 2013 | 09:33 PM
CoachRick's Avatar
Yeah, it's a darned if you do/don't type of scenario. I'll back in some days so I can let the engine heat travel out the garage door more easily, rather than being trapped in the garage...makes a difference when it's 105 outside!. I don't think exhaust fumes are too problematic if you only spend a few seconds upon ingress/egress with the engine running.
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
flybyglass
Sep 24, 2015 01:12 PM
