2018 RDX Tech - wheel allignment issues
Old Sep 8, 2020 | 11:55 AM
tinmaner's Avatar
so i recently took my 2018 RDX Tech for wheel alignment and the right rear camber is Negative 1.7
is this an issue ?
here are the complete measurements --
Left front
Camber 0.0
Caster 2.4
Toe 0.08
Right Front
Camber 0.1
Caster 2.6
Toe 0/03
Left Rear
Camber -1.2 (negative)
Toe 0.14
Right Rear
Camber -1.7 (Negative)
Toe 0.10
the Vehicle seems to be pulling to the left sometimes ( not all the time) what could be the issue ? any clues ?
Old Sep 8, 2020 | 12:56 PM
Mo_Green's Avatar
You need the ranges for all those values. Negative rear camber is expected with independent rear suspension...no surprise there.
Always ask for the before, after and range for alignment specs.
Old Sep 8, 2020 | 12:58 PM
tinmaner's Avatar
range as in the small letters ?
Right rear camber is the only one in red on the allighment printout and it says -1.5 to -0.5
Old Sep 8, 2020 | 01:15 PM
Mo_Green's Avatar
Range as in design acceptable tolerance. Red=adjustment is needed. Sometimes even a car that wasn't in an accident can be stuck a few tenths degrees out of alignment. Thus can't be adjusted; brought into the acceptable range.
arek1200
May 6, 2017 09:21 PM
Andrewsaintf
14
Jan 22, 2017 12:54 PM
rosalesmonterordx
1G RDX Problems & Fixes
Aug 3, 2010 07:45 AM
ericeash
1G RDX (2007-2012)
Apr 10, 2007 01:44 PM
