2018 RDX Tech - wheel allignment issues
so i recently took my 2018 RDX Tech for wheel alignment and the right rear camber is Negative 1.7
is this an issue ?
here are the complete measurements --
Left front
Camber 0.0
Caster 2.4
Toe 0.08
Right Front
Camber 0.1
Caster 2.6
Toe 0/03
Left Rear
Camber -1.2 (negative)
Toe 0.14
Right Rear
Camber -1.7 (Negative)
Toe 0.10
the Vehicle seems to be pulling to the left sometimes ( not all the time) what could be the issue ? any clues ?
is this an issue ?
Left front
Camber 0.0
Caster 2.4
Toe 0.08
Right Front
Camber 0.1
Caster 2.6
Toe 0/03
Left Rear
Toe 0.14
Right Rear
Toe 0.10
Right rear camber is the only one in red on the allighment printout and it says -1.5 to -0.5
Range as in design acceptable tolerance. Red=adjustment is needed. Sometimes even a car that wasn't in an accident can be stuck a few tenths degrees out of alignment. Thus can't be adjusted; brought into the acceptable range.
