2016 Cabin Air Filter
Old Jul 23, 2020 | 10:56 AM
Anovice's Avatar
How often should a cabin air filter be replaced? Miles and/or time?
Is it difficult to change and is there a YouTube video (I have no mechanical abilities)?
I see a few different brands on RockAuto. Due to shipping considerations (I am purchasing an oil and air filter and all three ship from the same location), I am looking at WIX. One is WIX part number 24815 for $11.03 and the other is WIX part number 24815XP which costs $13.12. The latter seems to filter out more elements. If I should replace the Cabin Air Filter, is WIX a good product?
Thanks much!
Anovice
Old Jul 23, 2020 | 06:20 PM
fjpthree's Avatar
Replacing the cabin air filter is probably one of the easiest DIY tasks you can perform. Takes minutes. I have used WIX in the past and they are quality products. Follow the MM for replacement. You could always pull out the old one to see if it is time to replace. It is a cheap fix and controls the amount of good/bad air you will be inhaling inside of the car:
Old Jul 23, 2020 | 09:10 PM
DUCRDX's Avatar
Strike Hold
Yeah, it's the simplest thing to do and doesn't get your hands or clothing dirty. Why do you think it's difficult?
I change mine yearly. But it's also on the Maintenance Minder (#2).
I use Fram Freshbreeze because it's cheap, is carbon impregnated, and can be found anywhere and everywhere.
Old Jul 24, 2020 | 12:03 AM
egads's Avatar
It is an every 30k item, fourth oil change when using oil life. the hardest part is clearing out the glovebox. Dealers want a fortune because it has been a time consuming task in older models.
Old Jul 26, 2020 | 09:27 PM
acuratech481's Avatar
We do them every 30k but it's so variable...if you park under trees or lives in the sticks it's for sure a more often thing. Especially with mice being a problem, it's best to just check it every 10k since it's easy to access. Don't wanna be breathing crappy air while you're out cruising! Lol
Old Jul 26, 2020 | 09:45 PM
egads's Avatar
Indeed on the crappy air. We once had a Civic, long before cabin filters. It needed a new evaporator/expansion valve assembly. The independant shop returned
the part to me. I would describe it as disgusting. Plugged up and moldy.
Old Jul 28, 2020 | 04:48 PM
AmbersDad's Avatar
Ick
Been there, done that...a couple times. This pic is from a week ago on Amber's new-to-her RDX!
harddrivin1le
TL/TLX Frequently Asked Questions
354
Jan 27, 2015 11:32 AM
tehCOW
Mar 2, 2006 02:33 AM
cambo
1G TL (1996-1998)
Mar 18, 2005 11:36 AM
gsrblack
Oct 20, 2004 05:08 PM
russianDude
Oct 20, 2002 08:10 PM
