p0740 problem code ????
Old Apr 5, 2005 | 11:43 PM
theleader's Avatar
hello there,
while i was driving home today on the highway the yellow triangle turned on and
the vsa light after that went on then check engine light turned on, i thought that somthing happend to the engine so i stopped on the shoulder i turned the engine off the i started it again hpefully the check engine light will be off but it still on ,
i went to my mechanic and after he plugged the car with his machine it says that
" torque converter clutch circuit malfunction " failure code p0740.
i remmber that a 2 weeks ago that i first notice problem in the transmission there was a gap between shifting from 2nd gear to the 3rd gear , and when i shift from
reverse to drive or the opposite.
what should i do ????
anybody had this problem and what you did ???
Old Apr 7, 2005 | 06:56 PM
DivinDude's Avatar
you appear to be suffering from the first major problem of Honda's 5 speed auto-tranny ... it's a matter of time before it dies ...
mada51589
Jan 9, 2025 04:40 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
IndycarFaster
Sep 11, 2015 02:52 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
