p0740 problem code ????
hello there,
while i was driving home today on the highway the yellow triangle turned on and
the vsa light after that went on then check engine light turned on, i thought that somthing happend to the engine so i stopped on the shoulder i turned the engine off the i started it again hpefully the check engine light will be off but it still on ,
i went to my mechanic and after he plugged the car with his machine it says that
" torque converter clutch circuit malfunction " failure code p0740.
i remmber that a 2 weeks ago that i first notice problem in the transmission there was a gap between shifting from 2nd gear to the 3rd gear , and when i shift from
reverse to drive or the opposite.
what should i do ????
anybody had this problem and what you did ???
mada51589
05-03-2022 08:54 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
IndycarFaster
09-11-2015 02:52 PM
HeloDown
09-08-2015 06:51 PM
