Tires losing air? No leaks? ???
That's Racist
One of my tires seems to be leaking air (@ about 1-2psi every day or two); I first found out because I had left the car alone for a good week (no driving @ all) and found out one of the tires was down to 15-20 psi .
Took it to firestone thinking i might have run over a nail or something; the guy told me he couldnt' find anything (yes he did the dunk to look for any leaks/nails or anything of the sort and still nothing =/.
Is there anywhere else that a leak could be coming from that wouldnt' show up under water? The rim does not seem to be bent or anything in any way so I'm not sure what to do =/.
Should I bring it somewhere else for a 2nd look?
cliff notes:
-Tire losing air @ 1-2psi a day
-Took to firestone got wheel dunked; no visual leaks
-wondering if there's other ways a tire could lose air.
cliff notes:
1st Gen CL Noob
It could be the slow leak common to aluminum-based rims.
Both cars I own have developed leaks 5-6 years later in its life due to natural "corrosion" which caused slow leaks around the rim, where the tire is mounted.
You will need to have the wheels "buffed/sanded" around the rims so that the tire sealant keeps a proper seal with the remounted tire to prevent from leaking air.
Consider it preventive maintenance.
I hope that helps.
I hope that helps.
3-piece FTW
Originally Posted by Time For Sleeep
If the leak is coming from the rivets; what am I able to do? Order new rivets?
They have a location in LA, and SF.
I hope that helps.
I hope that helps.
I never heard that? My rims never leaked air unless I had a leak.
Maybe it's coming from your valve stems.
I'd try somewhere else.
National Champs GO GATORS
The seal may be broken just a little, I would dismount the tire. Take the wheel apart, clean where the silcone used to be, very well, and reseal the wheel. Get the torque specs on the bolts before putting them back in. Remember to let the silcone dry for at least 24 hrs before remounting the tire... hopefully that helps.
ASM I.S. Design FTW.
I hope that helps.
I hope that helps.
I would listen to htown/standout's advice and have the sealant checked afterhaving dunked the entire wheel in a bathtub. If there's no leak, there should be no reason the tire is leaking air. Last I checked when I sold you these wheels, all the rivets were intact and perfectly fine.
LMK if you need any help.
yeah its doubtful that its leaking through the rivets, maybe the valve, but thats doubtful too. I would def take brianlin87's advice about putting the entire wheel/tire in the tub with water. Normally the when they are at a tire place its only part of the wheel at once. You may have a small crack in the tire that you really can't notice, try mounting one of the other tires from the other wheels to that one...
THE J35A2...
That's Racist
Hey all, (for the Socal peeps);
does anyone know a shop or anything that can basically just unmount the tire, and re-mount it/reseal it/possibly replace the valve stem?
Wheels of America and Wheel Repair specialists are both a no for me. (First said they don't do that kind of work, and the latter says I'm not able to go and wait there while the work is being done. )
BUMP!!
The same thing happened to me...had a slow leak (tire is fairly new) and took my car to firestone....they cleaned the corrosion from the rim and told me it was fine...sunday noticed it was low....took it back and they "fixed it"....today it was almost flat....Firestone told me i needed a new rim but when i called acura they said it needed to be buffed and bean sealer needed to be put on. Does this sound right?
not. i had this problem twice before. there is most likely a leak in the stem or the valve insert. just put your rim in a water bin and look for the bubbles. even at a gas station shop or tire shop can tell you where the leak is. i had to buy new valvestems for my rim before.
Originally Posted by marcy69
BUMP!!
Originally Posted by brianlin87
why are you calling acura? that in itself doesn't sound right at all. the OP has aftermarket 19" wheels, your problem has nothing to do with this thread.
We Are Venom
I know this is an old thread but let me shed some light on some questions. If you go to the gas station and fill up your tires, some of them don't drain their compressors often and now you are spouting air and water which causes mold to build up around the lips of the tires. This corrodes the rim/innerlip and needs to be sanded and buffed which any tire shop worth their salt can do. Just yelp and look at the reviews. I paid $30 and fixed my problem.
cycdaniel
12-17-2019 10:58 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
