Right Caster Question
Alignment shop printout today:
FRONT
Left Camber .5
Left Caster 1.9
Left Toe .01
Right Camber -.6
Right Caster 1.2
Right Toe 0.00
Total Toe .01
Steer Ahead 0.00
REAR
Left Camber -.4
Left Toe .08
Right Camber -.8
Right Toe .06
Total Toe .14
Thrust Angle .01
What is the cause & fix for the right caster?
Car as 35,000 miles.
FRONT
Left Camber .5
Left Caster 1.9
Left Toe .01
Right Camber -.6
Right Caster 1.2
Right Toe 0.00
Total Toe .01
Steer Ahead 0.00
REAR
Left Camber -.4
Left Toe .08
Right Camber -.8
Right Toe .06
Total Toe .14
Thrust Angle .01
Caster should be around 3 both sides. Wonder if those numbers are accurate.
I had similar situation where I went back to alignment shop and the numbers were totally different than the first time.
waxy1926
04-25-2016 07:21 PM
bsprinker
01-31-2016 02:16 PM
