Alignment: caster is nearly even...
Old Jan 20, 2016 | 09:34 PM
AcuraCls6speed's Avatar
Had my alignment done today. I'm used to seeing a split left and right but I just did my radius rod bushings and my caster is nearly even.
2.9 left
3.0 right
Question, is this ok? As far as driving it drives very straight but seems to have a vibe in certain conditions. Not sure if it has to do with the caster though.
Old Jan 20, 2016 | 11:10 PM
WheelMcCoy's Avatar
Caster can be slightly different to accommodate the crown of the road.
Vibrations are usually not due to suspension alignment, but because tires are out of balance, or worn unevenly.
Here's an excellent video explaining alignment:
Old Jan 21, 2016 | 10:46 AM
01acls's Avatar
Yes, your caster it's ok. The caster is not adjustable and should be the same or close to it.
02tlnate
Jan 12, 2016 03:11 AM
yingers
Jan 11, 2016 04:13 PM
