Planning to get Tein Basics
Old Jan 28, 2008 | 09:30 AM
dru2's Avatar
Hey there I'm planning to get a set of Tein Basics coilovers.
Since the car itself is heavy, my question is if I need camber kits to go with it.
If so, which one would you recommend for this setup?
Old Jan 28, 2008 | 01:34 PM
DLntheCL's Avatar
sounds like your new and confused. camber has nothing to do with the weight of the car. most likely you will need a camber kit, depends on how low your going to go. ingalls or spc is recomended, do a search there is ton of info. expect to pay around 400+
Old Jan 28, 2008 | 04:34 PM
underst8's Avatar
140,000 miles young
like DL said, it will depend on how much you lower it. Considering you are getting coil overs and thus will likely drop it quite a bit, I'd say you will probably need one, especially in the rear.
Old Jan 28, 2008 | 05:16 PM
smokendsm's Avatar
ridin slow'n'low
I have a set of these waiting to be installed, but plenty of other people run them.
When the time comes, definitely buy them from one of the forum vendors (marcus/heeltoe is a good dude)
Old Jan 28, 2008 | 07:23 PM
DLntheCL's Avatar
also excelerate
Old Jan 28, 2008 | 07:42 PM
smokendsm's Avatar
ridin slow'n'low
Yeah, sorry. Excelerate is top notch as well!
Old Jan 29, 2008 | 10:21 AM
Excelerate's Avatar
Former Sponsor
Camber kits are for adjustment of toe and camber and those change when you change the suspension, esp when you lower the car. In order to know for sure whether you need a camber kit you will have to get an alignment after lowering the vehicle. That will let you know whether a camber kit is required. Most CL customers just need the rear kit, unless they slam the car.
PM me if you need the TEIN coilovers or camber kits.
08KBP_VA
Oct 22, 2019 01:55 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
lanechanger
Oct 13, 2015 10:56 AM
hashbrown
Sep 29, 2015 12:13 PM
