lowering question?
Old Aug 29, 2006 | 04:57 PM
bmehling's Avatar
lowering question?
I want to keep the best ride possible so I will go with the tanabe normal feel springs.. My question is the car has 70k on it but mostly highway miles. Will I need anything else besides springs. Shocks....struts.....exc.....I also might put on a little taller series tire eventually for a softer ride.
Old Aug 29, 2006 | 05:41 PM
bim6180's Avatar
get the shocks too.....do it all at once...save you time and money. I recommend Bilstein sport shocks...you have life time warranty on it...and it's a trusted name. Koni yellow and Tokico is your other option
Old Aug 29, 2006 | 05:46 PM
bmehling's Avatar
whata re the best shocks for ride quality. Im trying to keep my soft ride
Old Aug 29, 2006 | 05:55 PM
Lord Helmet's Avatar
I'm here in spirit...
Yeah, with that milage I would recommend doing struts at the same time too. Ive heard good things about those Bilstein's. PM NiteQwill and ask him how he likes his. He's the only person I know of off hand who is running those besides bim6180 above me.
Old Aug 29, 2006 | 06:42 PM
bim6180's Avatar
with any aftermarket shocks that you'll get, it won't be as soft as your stock shocks. I've never had koni or Tokico, but BIlstein sport is not rough by any means, It absorbs bumps really well. I live in New England, and the roads here are not the best. I have 18" wheel with 40 series tire, and the ride is great.
If you're not going to mess around with the damper setting, get bilstein or Tokico Blue. Koni and Tokico white are both adjustable (from soft to really hard setting). But personally, i go with Bilstein...again, well known and trusted name...backed with life time warranty... Can't really beat that
Oh...also...do the install yourselve. Nitequill has a great/detailed DIY with Pics and stuff....good luck
Old Aug 29, 2006 | 07:08 PM
It was so easy with that write up.
Old Aug 29, 2006 | 08:18 PM
bmehling's Avatar
so yall would recomend shocks and struts. Man this is gettign expensive.
Old Aug 29, 2006 | 08:20 PM
bim6180's Avatar
yes, you've already had 70k on your stock shocks. If you don't change it now, you'll be forced too in the next couple of months after installing your springs. Then, that'll cost you even more. If you want, just wait a couple more months, and do both at the same time. Trust me, you DON'T want to do this twice.....
Old Aug 29, 2006 | 08:38 PM
bmehling's Avatar
but one guy said shocks and struts?
Old Aug 29, 2006 | 08:52 PM
bim6180's Avatar
don't get confuse...we have shocks at all 4 corners. Althought struts and shocks terms are usualy used to describe the same thing, they are two different things. Can't really give you tech explanation of struts right off hand, but you can do a search on the website.
Anyways, we have Shocks on all 4 corners.
So, get the spring set you want, plus 4 shocks (2 rear, 2 front), and install
Old Aug 29, 2006 | 08:56 PM
bim6180's Avatar
Ok,
here is some tech for you on struts, hope it didn't get you even more confuse
http://www.monroe.com/tech_support/tec_struts.asp
Old Aug 29, 2006 | 09:04 PM
bmehling's Avatar
so I dont need struts..just springs and shocks
Old Aug 29, 2006 | 09:49 PM
bim6180's Avatar
yes...just springs and shocks, there are no struts available for our cars ....even if you try to find one. IF you do go with bilstein, you have to get the one for 98-02 accord V6...I think the part# is BE5-6580-H0 for front and BE5-6581-H0 for rear...
http://www.ajusa.com/cgi-bin/bilstei...026675e0945c76
That's the best price i can find for bilstein shocks
Old Aug 29, 2006 | 11:47 PM
o1s's Avatar
o1s
or go with a set of full coilovers. a little more, but, you get the exact height adjustment that you want. tein basic coilovers are softer than stock shock/springs. or at least they feel like it to me.
KB1_EJ6
Aug 28, 2016 08:25 AM
VolkingTL
Sep 16, 2015 09:10 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
gqdabien
Sep 8, 2015 11:41 PM
