How's the brake replacement?
Old Jul 29, 2008 | 09:55 AM
dannypio's Avatar
Hi, my 2002 CL has 62,000 miles, and not sure if brakes changed since new. Going under the car tonite; how hard is it to change the pads and what do I need to watch out for? Do I need to scuff them before install? Any issues with the antilock brake wiring etc? My state inspection is this week and I need to pass it. Thanks.
Old Jul 30, 2008 | 06:19 PM
danny25's Avatar
bump because I'm about to try to replace my brakes and rotors tomorrow.
are any special tools needed like a caliper spreader?
Old Jul 30, 2008 | 06:38 PM
smokendsm's Avatar
ridin slow'n'low
you will need a c-clamp
Old Jul 31, 2008 | 02:13 AM
xBlur's Avatar
wants mods
And an impact driver will definitely be helpful.
This is what I used when I did my rotors.
http://www.cardomain.com/ride/184466/23
P.S. Remember to take off the parking brake when doing the rear rotors.
Old Jul 31, 2008 | 07:38 AM
fuzzy02CLS's Avatar
It's the same as any brake install on any car. Hardest part will be getting the screw out of the rotor. You don't want to strip them hence the impact screwdriver.(drill them out if they do get stripped.
A c-clamp to compress the caliper piston(to fit the new pads in), make sure you remove the master cylinder cap & put a shop towel around it 1st since it will push some fluid out.
That's really it. There's a write up in the FAQ.
Old Jul 31, 2008 | 10:34 AM
danny25's Avatar
thanks smokendsm
thanks a lot, great link!
Old Jul 31, 2008 | 10:39 AM
danny25's Avatar
Sure enough... https://acurazine.com/forums/showthread.php?t=143291
I didn't change the filter to look back far enough
thanks fuzzy!
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
gqdabien
Sep 8, 2015 11:41 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
