Finally lowered on Function/Forms but.....
Old May 10, 2012 | 12:37 PM
rickike99's Avatar
I am finally lowered on f/f coils and now have a vibration that shakes the entire car during acceleration. I have had my tires balanced, rotated, and aligned. I lowered it only 2 days ago so should I just give my car time to get used to the drop? Or could this be a more serious issue?
Old May 10, 2012 | 03:44 PM
tommystyle86's Avatar
I believe it has something to do with the axles, I cant remember exactly what my buddy told me when i had this same issue but i believe he said the axle itself was off balance
Old May 10, 2012 | 05:27 PM
rickike99's Avatar
Thanks man, yeah I talked to a bud of mine and he said that it was most likely the angle of the axle from being lowered. All I need is the camber kit and it should even out the axles.
Old May 10, 2012 | 06:11 PM
civicdrivr's Avatar
Its definitely the axles. The joints are worn.
Old May 10, 2012 | 06:32 PM
rickike99's Avatar
You think so? Cause I know I'm going to have to get adjustable ball joints/camber kit so that may help a little by evening out the axle. But how much do you think the joints will run me?
Old May 10, 2012 | 07:52 PM
civicdrivr's Avatar
If you can install them yourself, no more then $175 for both.
Old May 10, 2012 | 08:57 PM
Italiano's Avatar
How low are u..u only get that if your tuckin tire...mine does it...when I was dropped 1.7 inches it didn't do it..now that I'm 2.5inches slight vibration around 3rd gear then goes away...I have ingalls rear camber kit...still does it....
Old May 10, 2012 | 09:24 PM
civicdrivr's Avatar
The bearings have probably been worn this entire time, but once he changed the angle it put more stress on them making the failure apparent.
Old May 10, 2012 | 10:54 PM
rickike99's Avatar
I appreciate it guys, I'm about 3" down in the front and two in the back and I plan to even the car out once I roll the rear fender. I'm planning on installing front and rear camber kits. If that doesn't help with the vibrations, I will then get new joints and probably replace the axles to make sure everything is straight.
Old May 11, 2012 | 08:52 AM
Italiano's Avatar
No wonder...lol
08KBP_VA
Oct 22, 2019 01:55 PM
vpasla1
Sep 17, 2016 07:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
rhdune16
Sep 28, 2015 11:31 AM
