extended lugs?
The Sicilian
You should be fine. I put 5mm spacers on the back of my 2003 Maxima. The general rule is that you should be able to turn the lug nut 8 rurns for it to be safe enough.
Ya he probably means look wise, but it was just enough for the Max.
For a 12x1.5 lug nut, the minimum number of turns should be 6.5. I have barely that with a 3mm spacer. If it were my car I'd go with extend lugs with a 5mm spacer but it's your car so it's your choice.
http://www.tirerack.com/wheels/tech/...urrentpage=102
neuronbob
23
07-16-2019 10:48 AM
