Car pulls like crazy
I have an annoying problem my car pulls like crazy to the right
I don't know if it's b/c i need an alignment or if i need a camber kit. I had my dropped for some time now and never went to get it aligned
So what do u guys think do i need a alignment or camber kit? And if i need a camber kit how much does that cost?
If your car is lowered, the wheels can tend to ride like this /-----\ . Camber kits adjust so it rides normally. |-----|
Although it's possible to be off in camber even if you're @ stock height. *raises hand*
Why is that the high end cars i have seen like bmw m3's rear wheels look like that /----\
or are all the cars ive seen like that lowered and their camber has not been adjusted? or does it serve a purpose to have the camber like that?
its always a good idea to go and align your wheels after a drop... its also a good idea to get the camber kit too if you dropped it low - (If your wheels fold inwards then you have negative camber) negative camber = wearing out inside of tires ALOT faster than normal = new tires in just a couple monthshow agressive of a drop is it?
heheand the purpose negative camber serves is to remind everyone who drives behind the sucker with it that they forgot to go buy a camber kit and that their tires are gonna blow any second from that point
I have a friend that used now has a beater 240 which he uses for drifting. He used to autocross too. He keeps his 240 @ a negative camber on purpose cause I guess it helps for those kind of situations? (If anybody is into drifting).
He has special tires though that are made to be thicker on the inside than the outside I believe.
My car is lowered and it look like my tires are a little worn inside.. As a matter of fact i can see a little thread not metal though damn!
My car is dropped two inches on eibach springs.
