Camber Kit question
666 Speed
Camber Kit question
On some ebay auctions (http://cgi.ebay.com/ebaymotors/Ingal...QQcmdZViewItem) it says that that camber kit will fit the first gen along with the second gen CL's
Question is, Will it or is it just a sales catch?
Looks like it's the same part for both applications. Check out the Ingalls catalog.
Yup. It's the same:
http://www.ingallseng.com/parts/35590.htm
Part number matches the e-bay description.
Former Sponsor
Actually it is possible it won't work with some first gen CL'.s It will work for all 2nd gen CL's but if you have had a ball joint changed they may have changed the upper arm and then you would need a different part # 35595 I believe it is.
I think this is a better Ingalls solution than the ball joint one:
http://www.ingallseng.com/parts/39201-39204.htm
Former Sponsor
Originally Posted by artbran
EXCELERATE, what do you recomend for camber kits front and rear for an 03?
Ingalls Camber Kits
BoricuaTL
Apr 8, 2016 01:08 PM
nuldabz
Sep 3, 2015 05:49 PM
