19x8" Offset Question, Yeah Yeah, Again
First of all, would 19x8" wheels fit without rolling my fenders (with proper offset)?
Secondly, what would fit better, 42mm, 45mm, or 48mm offset?
I will have Tein Basics iinstalled and about a 1-2 finger gap with the 19s.
TIA
TIA
i hope this helps i have 19x8 rims with a 40 offset and i had to roll my fenders i only really rub on really big dips in the road so i would think you wont have that trouble with a higher offset.
If you want less work, stick in the +45/+48 and up range. I have 19x8 +45 with 235/35 tires all around, plus eibach pro kit drop (1.5 finger gap all around). My fenders are not rolled. The car rubs in the rear on hard corners/big bumps. I probably won't have the problem once I roll the fenders, but tire size could play a part in this too.
225/35 19 will be thinner and have a little tire stretch, which some seem to like...the roads are bad here, I have enough trouble keeping my wheels protected with the 235/35s. Make sure and take that into consideration.
More pics Lippstuh, how'd you pull off the low offset? What tire sizes are you running.
thread jacked.... yeah the vs-xx were my old 8 and 9 fitment, my new fitment should be here next weekend.
anyways tires play a big roll, just run 225/35/19 and you should be able to fit any of those offsets. camber + height plays a roll as well.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
