19's on Tein's
Old May 30, 2007 | 01:51 PM
infuzeon's Avatar
'01 Acura CL-S
19's on Tein's
Looking to get 19 x 8.5" rims.. whats the minimum or maximum offset I should be looking at? Also going to be lowered on Tein SS's..
Would 19 x 18.5" fit right (meaning no rubbing) or should I be looking at 19 x 7.5" instead?
Old Jun 2, 2007 | 01:46 PM
SiCrew's Avatar
If you're looking at 19's, dropped fairly low on TEIN SS, your ideal/safe setup would be something along the lines of a 19x7.5 with at least +45 offset. I'm currently running 19x8 +45 with TEIN SS and trunk audio, and I don't rub. However, if you want to be safe, stick with the 19x7.5 and a +45, you should be fine. You "can" run a wider wheel or a lower offset, at the risk of rubbing, where you might be able to fix the problem by rolling your fenders.
All in all, I would just recommend buying wheels that fit properly, so stick with 19x7.5 with at least +45 if you're looking to roll dropped on 19s. Hope that helps.
-Andy
Old Jun 9, 2007 | 09:01 AM
GreggieP's Avatar
Do the SS Tien's have a more drastic drop than the H-Tech Tiens?? I am planning on running 19's but don't wanna be slammed. Just wanna have a lower look with the bigger wheels. Thanks
Old Jun 9, 2007 | 12:38 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Tein SS are a coliover setup with an adjustable ride height and dampening. The H-tech are springs only and are non-adjustable and need to be paired with either the oem shocks/struts (not very recomended) or aftermarket shocks/struts like Tokico, Blistein, or Koni.
Old Jun 11, 2007 | 04:57 PM
GreggieP's Avatar
Ahh, yeah ok, sorry bout the mix up, I was curious about the difference on the Tien S-Tech and the tien H-techs. I plan on upgrading the shocks/struts too, probably going with the KYB's with the H-Techs, but wanna know if that set-up with 19's would be fine compared to 19's dropped with the S-Techs???
Old Jun 27, 2007 | 09:39 PM
infuzeon's Avatar
'01 Acura CL-S
So I have my mind pretty much set on these 19x8.5" Zinik wheels with +40 offset. I realize I'm going to be rubbing for sure with this set up but my cars already in the body shop and I can get the guy to roll my fenders while its in there practically for free so thats not an issue.. and I'm getting an amazing deal on the wheels so everythings going to work out..
Is there any other problems I should be aware of if I put on 19x8.5"s with +40 offset other than having to roll the fender? I believe the tire size is 235/35/19.
Old Jun 28, 2007 | 04:23 AM
Time For Sleeep's Avatar
That's Racist
if your mind is set on those wheels. change it.
it will look terrible. it won't just rub, it will look silly lol
Old Jun 28, 2007 | 05:49 AM
distortedolskool's Avatar
agreed. please keep wheel shopping.
Old Jun 28, 2007 | 08:17 AM
infuzeon's Avatar
'01 Acura CL-S
Alright so 18x7.5" with +42 offset.. better?
Old Jun 28, 2007 | 01:27 PM
yes. much better.
BTW what do these wheels look like? i see Zinik
Old Jun 28, 2007 | 01:40 PM
infuzeon's Avatar
'01 Acura CL-S
Those are the wheels right there..
http://www.zinikwheels.com/z21d.jpg
I'm assuming I'll have camber for sure so I should just get SPC or Ingalls camber kit and do it all at once huh?
Old Jun 28, 2007 | 05:41 PM
on the wheels. yes on the camber kits being required.
Old Jun 28, 2007 | 09:23 PM
njzprettyboy's Avatar
y
Old Jun 28, 2007 | 09:42 PM
Originally Posted by njzprettyboy
y
just not fond of those but wheels are a personal taste. anyone know anything on this brand?
your car...your wheels!
Old Jun 28, 2007 | 09:57 PM
infuzeon's Avatar
'01 Acura CL-S
thanks for your advice & opinion
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
4drviper
Sep 23, 2015 07:42 PM
