XLR8 Motor mounts??
Old Jul 31, 2012 | 08:09 PM
SpaghettiOs's Avatar
XLR8 Motor mounts??
i need new motor mounts for my 01 cl-s auto, anyone know if XLR8 are a good alternative to stock? why or why not?
Old Aug 1, 2012 | 02:07 PM
mikebikelife's Avatar
@Mikeshlong On IG
And not to thread jack, But is there a time when you should replace them or just when they are worn out ? otherwise dont change them ?Mines auto too .
Old Aug 1, 2012 | 02:09 PM
one would only have to read the description:
XLR8 Performance’s Engine Mounts were engineered with longevity, performance and value in mind. Many Acura enthusiasts are having issues with broken motor mounts. These mounts are heavy duty mild steel mounts that have been coated with a satin black finish and improved polyurethane bushings that range in firmness. Controlling the durometer of the polyurethane inserts minimizes engine movement. We offer 3 different durometers of inserts, which are available at no additional cost. When ordering, specify whether you want: Street (62A) or Strip (75A) polyurethane inserts. The polyurethane inserts also have a lifetime warranty.
Old Aug 1, 2012 | 02:11 PM
Motor mounts are rubber.
when accelerating, the engine torques or moves.
these rubber mounts can tear.
when they tear, they can cause vibrations inside the cabin.
since the engine is moving MORE than normal, it can rip other mounts causing other kinds of damage.
Old Aug 1, 2012 | 02:21 PM
by changing out to a stiffer mount, you will feel the engines vibrations MORE.
Old Aug 1, 2012 | 03:43 PM
dude mine are so worn its not even funny. im at 130k miles
Old Aug 1, 2012 | 09:32 PM
civicdrivr's Avatar
The bushings collapsed on the XLR8 mounts after 7k miles, I just havent had the time to pull them out of my car (plus I havent driven it since May). Another member had the same issue in an even shorter amount of time, but he sold his car shortly thereafter. The side mount didnt line up with the holes on the frame rail, so I had to drill them out.
OEM mounts arent much better for me either, though theyd typically last about 30k. But once I began to fill them with polyurethane, they began to last longer then that.
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
