XLR8 Motor mounts??
one would only have to read the description:
XLR8 Performance’s Engine Mounts were engineered with longevity, performance and value in mind. Many Acura enthusiasts are having issues with broken motor mounts. These mounts are heavy duty mild steel mounts that have been coated with a satin black finish and improved polyurethane bushings that range in firmness. Controlling the durometer of the polyurethane inserts minimizes engine movement. We offer 3 different durometers of inserts, which are available at no additional cost. When ordering, specify whether you want: Street (62A) or Strip (75A) polyurethane inserts. The polyurethane inserts also have a lifetime warranty.
mikebikelife (08-01-2012)
Whats up with RDX owners?
The bushings collapsed on the XLR8 mounts after 7k miles, I just havent had the time to pull them out of my car (plus I havent driven it since May). Another member had the same issue in an even shorter amount of time, but he sold his car shortly thereafter. The side mount didnt line up with the holes on the frame rail, so I had to drill them out.
OEM mounts arent much better for me either, though theyd typically last about 30k. But once I began to fill them with polyurethane, they began to last longer then that.
The following 2 users liked this post by civicdrivr:
justnspace (08-02-2012),
SpaghettiOs (08-02-2012)
08_UA7_Gr33k
02-11-2016 02:17 PM
xsilverhawkx
09-28-2015 06:51 PM
