Worth it to fix?
Old Mar 3, 2018 | 01:08 AM
pb06's Avatar
Arrow Worth it to fix?
I drive a 2001 CL. My check engine light has been on for months. I finally brought it in and was told that it needed new oxygen & temperature sensors, and a new accessory drive belt. By the time they had done the diagnosis, they were closing up for the day. They said there was no problem driving it this way unless it started acting up. Last night, as I was driving home -- at about 45-55 mph, suddenly the car lurched when I accelerated, then pulled back a few times. The RPM was jumping from 1 to 2 & back again. I let my foot off the gas and it stopped, but repeated again a few minutes later. I managed to get home without it happening again by driving slowly.
I took it in today and after waiting 6 hours, they said they had a different code and told me the valve cover gaskets were leaking and I needed a new intake manifold. (They also said I needed a new thermostat but that could wait). They wanted to charge $560 for just the intake manifold & gasket cover.
The car also needs other more expensive repairs that I've chosen not to do (engine mounts) because I was planning on buying a new car soon. I leave in a week to go out of town for an extended period, and I was hoping it would hold out till then. Again, they were closing up shop, so they couldn't do it today. They couldn't ge the part till Monday, so I drove home -- on the way, the car felt a little lurchy again. So my questions are --
Is it worth getting this fixed? (Vs. just rent a car till I'm back in town and can buy a new car?) I think the bluebook value of the car is about $1000-1200.
Will it make any difference on the trade-in price if it's repaired?
Does this pricing sound right?
Does the diagnosis sound right?
Is this something I can drive with for a week or two am I taking too great a risk?
My trusted mechanic retired a few years ago; I know nothing about cars, so I've been at a loss ever since. I appreciate your thoughts.
Old Mar 3, 2018 | 07:59 AM
teh CL's Avatar
Did they tell you why you need an intake manifold?
Old Mar 3, 2018 | 08:33 AM
horseshoez's Avatar
Latent car nut
I'm thinking time for a second opinion.
Old Mar 3, 2018 | 09:51 AM
pb06's Avatar
They said it had a leak & that was the cause of the jerky acceleration. I needed that and a valve gasket replaced.
Old Mar 3, 2018 | 09:53 AM
pb06's Avatar
Why? Does it sound too high to you?
Old Mar 3, 2018 | 10:01 AM
horseshoez's Avatar
Latent car nut
I wrote that when we understood you needed a full new intake manifold; it looks like you've since posted you only need a new intake manifold gasket. While a new gasket sounds a bit sketchy (they almost never fail), a full new manifold is virtually never required.
Old Mar 3, 2018 | 01:36 PM
pb06's Avatar
I see. I don't know the difference. Does $560 sound like the right price to you?
Old Mar 3, 2018 | 01:39 PM
horseshoez's Avatar
Latent car nut
I suppose, I mean, it does sound a bit high, however, I'm questioning the actual need. I'm still thinking a second opinion is warranted.
Old Mar 6, 2018 | 12:28 AM
pb06's Avatar
i got it repaired but I’m not sure it’s entirely fixed the problem. It runs better but it shudder when I turn off the engine and the acceleration feels a little wonky, although more subtle now.
Old Apr 13, 2018 | 11:17 AM
potter223's Avatar
Post Ecu?
Its your ECU barometric sensing unit.
Take it to Acura.
Old May 10, 2018 | 10:01 PM
pb06's Avatar
Went to a second shop. Agreed it was the intake manifold. Charged me $400 to fix.
Before I left town a week later, it was already feeling a little jerky again.
I go away for a couple of months, come back, driving it less than a week, the problem returns. Check engine light comes on. Tonight at a light, it started revving & then slowing, like it was going to lurch through the intersection, then like it was going to just shut down on me. When the light changed & I hit the gas, it stalled -- it would hardly accelerate. It wasn't responsive to me pressing the pedal at first, then seconds later, it zoomed off at 40mph. It kept lurching and stalling, so I turned around and came back home. I've driven it less than 20 days from the day it was "repaired". So I guess you guys were right and two mechanics were wrong -- it either wasn't the manifold or it wasn't fixed properly.
I plan to call the shop up tomorrow and I hope they don't try to shake me down for more money. Think I'm owed a proper diagnosis and repair this time.
Q: Could it be spark plugs or coils? It did something similar years ago and that's what it turned out to be.
Q2: Could it have anything to do with using regular gas v.premium?
Thanks for your feedback/input. I know nada about what's under the hood. Except that I should be looking for a new car.
Old May 10, 2018 | 10:10 PM
pb06's Avatar
Take it to Acura.
Thanks, I don't know what that means. ;-)
They've also told me I need new engine mounts. I'm thinking that's not causing this problem, right?
Old May 10, 2018 | 11:40 PM
01acls's Avatar
Your best options are to find a good trusted mechanic or buy a new car.
Asks a trusted friend for a recommendation to a good mechanic or start shopping for a new car.
Old May 11, 2018 | 03:35 AM
pb06's Avatar
How do you like the Mazda 3?
Old May 11, 2018 | 11:10 AM
horseshoez's Avatar
Latent car nut
My wife and I like our Mazda3 a lot; a nice tight and maneuverable package with good room for four adults and some cargo in the hatch. The car gets good fuel economy (my wife typically gets about 32 mpg on a normal day-to-day basis), has good steering feedback, has a very light clutch and shifter mechanism and is a joy to drive. What I don't like it, and this criticism can be extended to include many/most modern cars, is the stupid multifunction screen; Nav, Audio, Trip Computer, and other functions are all grouped on the single screen which is basically single function. I much prefer my "old" car with regard to the above functions, all of them have their own discreet display (I use an aftermarket Garmin NAV unit), and to me require a lot less time with my eyes off the road compared to most new cars.
Old May 11, 2018 | 12:18 PM
pb06's Avatar
I haven't driven one yet, but I'm curious. I'd like to replace my car with a plug-in hybrid -- good rebates in CA -- maybe an Accord, Sonata, Ionic or mini. But some models I like, like the M3, don't offer a hybrid option yet.
Old May 11, 2018 | 12:21 PM
horseshoez's Avatar
Latent car nut
Word on the street is Mazda ain't gonna do a hybrid anytime soon, if ever. Personally I have exactly zero use for a hybrid so I could care less.
SI Guy
Sep 4, 2009 09:53 AM
JZG-ED
Aug 14, 2008 09:19 AM
pjoseph
Nov 1, 2007 11:39 AM
arstraub
Sep 22, 2006 09:27 AM
jen
Mar 22, 2006 07:03 PM
