Window & Locks
Old Aug 24, 2010 | 02:19 PM
Frank109's Avatar
Window & Locks
2001 CL Type-S
Hey guys sorry if this was brought up before... Sometimes the driver side window has trouble getting back up. It gets stuck half way and i have to pull it up with my hands while trying to roll it up. Is there an easy/cheap fix? maybe the motor is going bad?
My passenger side lock wont work with the alarm or open/close with lock latch. it has to be opened with key or from the inside by hand. the driver side lock sometimes locks itself and i get stuck outside of my car. when it is stuck, i hit unlock with alarm and the lock clicks up half way and goes back down then i have to open the door with the key and have to twist really hard.
anyone know how to fix these minor and very annoying issues?
Old Aug 30, 2010 | 12:54 PM
PANAMARED's Avatar
i would first remove panel and check all connections (electrical and mechanical)...
Old Aug 30, 2010 | 01:22 PM
NSXNEXT's Avatar
1st issue sounds like the motor is going bad. A simple fix is to wipe silicone inside the rubber track that guides the sides of the window. Roll down the window, clean out the rubber window track with soap and water then spritz some silicone lubricant on a q-tip and wipe it up and down the track.
Old Aug 31, 2010 | 02:02 PM
Frank109's Avatar
I will try this. Hopefully it'll work and be a great cheap fix. ill get back to you
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
