Wierd Noise
Old Apr 20, 2009 | 10:58 AM
karanmc's Avatar
Wierd Noise
If you guys could help me figure this.....Driving an 01 ClS while pushing the gas pedal i hear a TICK noise just once from somewhere in the front, so everytime i press the gas pedal from 0 it does that...i am wondering if anyone of us experienced the same?
Old Apr 20, 2009 | 11:01 AM
jaysizzlecity's Avatar
B A N N E D
might be engine knocking.......
Old Apr 20, 2009 | 11:03 AM
karanmc's Avatar
but i got it checked from my mechanic when i bought it and he said the engine is perfect so is the suspension. Out of any guess, could it be the MOUNTS?
Old Apr 20, 2009 | 11:09 AM
02CLNOS's Avatar
how many miles?
do you accelerate hard?
could be:
your valves
if your not using the correct gas
Old Apr 20, 2009 | 12:37 PM
karanmc's Avatar
Originally Posted by 02CLNOS
how many miles?
could be:
your valves
Well yeah maybe once out of blue but mostly i try to be as gentle as possible from zero, but is there a way to check the valves, btw i always put ESSO'S SUPREME and all top quality fluids for my car
Old Apr 20, 2009 | 01:00 PM
CLPimpin114's Avatar
Tokin up in
Ball Joints Maybe??? Does it do it when you turn??
Old Apr 20, 2009 | 02:51 PM
karanmc's Avatar
i got it inspected too like 2 weeks ago and the guy said they are strong...COULD IT BE THE BRAKES BY ANY CHANCE
Old Apr 20, 2009 | 03:13 PM
B A N N E D
do you use 91-93 octane......?
Old Apr 20, 2009 | 04:26 PM
Zippee's Avatar
Could be a brake pad being pushed out of the way. Does it do it every time you start or only if you backed up. then went ahead like baking out of a parking spot?
Might also try slightly dragging the brake and see if that stops the noise.
Old Apr 20, 2009 | 05:03 PM
karanmc's Avatar
I dont remember reading that but I am positive about the Esso Supreme which is the most expensive premium gas i believe?
Old Apr 20, 2009 | 05:04 PM
karanmc's Avatar
It does it most of the time when i start but most of the time....I am thinking there is some issue with the break pads maybe they are the not the best quality, maybe time for a replacement for some good ones
Old Apr 21, 2009 | 01:03 PM
Jacobpockros's Avatar
Motor mounts?
Old Apr 21, 2009 | 05:57 PM
phipark's Avatar
Not Asian
Do you feel a hesitation or a shift from the engine?
Old Apr 21, 2009 | 07:16 PM
karanmc's Avatar
Originally Posted by Jacobpockros
Motor mounts?
No Motor Mounts
Old Apr 22, 2009 | 06:47 PM
AnthraciteBeast's Avatar
interested in this.....dont have an answer but subscribed
Old May 17, 2009 | 02:04 PM
BAGII's Avatar
So, it's just 1 tick when you hit the gas? It's not multiple ticks like tick tick tick . . . I'd say it's something in the suspension or brakes. Something shifts everytime you hit the gas. It could be a loose bolt underneath. I'd give everything a good look down.
Old May 25, 2009 | 06:35 PM
Elijah J's Avatar
YES! Absofuckinglutely! same shite happened to me last year. Changed the mounts ~ nothing. Had joints looked at ~ no problems. Took front wheels off...poked around and recreated the exact annoying ass ping noise but flicking a thin metal guard on the rotor. Apparently, that little piece(sorry 4 the crap description...) gets touched in a way it doesnt like and pings at you because of it(keep in mind it had aftermarket pads and rotors). So...yeah, good luck I just drove on it until I needed brakes, changed them and the noise went away...
Old May 25, 2009 | 08:04 PM
eric paulson's Avatar
4th Gear
I had the same issue, it was a electic little gadget on the fire wall. Forgot what it was. It makes noise, especially when it is cold outside. Really bad in the low single digits. not an issue, but now I have one coming from under the car near the rear wheel. Fuel pump???hope not.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
