Weird problem with car refusing to start
Old Oct 2, 2010 | 06:42 PM
DRO916's Avatar
2001 Acura CL-S
My car has intermittently refused to start throughout July-September; I noticed this only happened during very hot days here in Sacramento, CA (Roseville).
Upon inspecting my battery the first few times this happened, I noticed tons of blue corrosion (reminded me of blue raspberry slushy) on the terminals. I cleaned the caked up terminals out without any solution. Car works fine.
Then it dies again a few weeks later; battery terminal build up is back. I use the spray solution and protector, cleaned it up a lot better this time, car works fine.
Car won't start again. I research online and I find threads with people having similar symptoms; they mentioned the culprit being the car sitting under the hot sun and fuel pump relay going out. I changed and bought a new fuel pump relay and the car still didn't start. I jumped it and it starts and works fine for the next couple of days.
Then it won't start AGAIN. I have the battery checked and it's toast. I get a new battery and car works fine for 3 days and then the car doesn't start again (after I left it under the hot 108 degree sun that day). Thinking my battery wasn't being charged because of the alternator being shot or either getting drained from a short in the electrical system, I get the battery checked yesterday and surprisingly it's FULLY CHARGED (the readout receipt says 700+ cranking amps).
Current, outlined symptoms:
  • Brand new, fully charged battery
  • Brand new fuel pump relay
  • Car just clicks and doesn't start
  • Starts with jumper pack or by getting a jump from another car
  • I noticed smoke coming out of the terminals if I try to start it without jumping -very puzzling
I ruled out alternator since the battery was still fully charged after having the problem. I ruled out a short in my electrical system for the same reason. My only guess would be to get new battery cables.
What do you guys think?
Old Oct 2, 2010 | 07:49 PM
civicdrivr's Avatar
Im leaning towards battery cables as well. The smoke coming from them while to attempt to start is highly alarming.
You can make your own cables. Just get 1/0awg cable and weather proof connectors. Run new cables from the battery (+) to the fuse box, battery (+) to starter and battery (-) to ground.
Old Oct 4, 2010 | 01:09 AM
DRO916's Avatar
Thanks for the co-sign/suggestion! Yeah I'll def inspect them more tomorrow and have them replaced if need be, then report back...
Old Oct 5, 2010 | 12:55 AM
BAGII's Avatar
Well I would rule out wiring if it starts when you hook up a jumper pack. I would double check battery charge. You might have some parasitic draw. Make sure all your lights stay off when you lock your car, stuff like that.
Old Oct 5, 2010 | 01:52 PM
aznboi2424's Avatar
any progress on this? I hate dealing with eletrical problems.
Still see you trying to sell your 1 CL-S rim on craigslist lol
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
